Author Topic: What is the best material to "dampen" the sound of an aluminum case?  (Read 1746 times)
Offline ArchDill
Got a new case today and I really like it but it has an odd sound compared to my last. I have seen foam used. What do you all recommend? Thanks for any help!!
Re: What is the best material to "dampen" the sound of an aluminum case?
« Reply #1 on: Wed, 28 December 2016, 01:36:36 »
Putting some cushioned material lining the case can both improve overall feel and dampen sound. I like this stuff, and it's easy to cut to any size.
https://www.amazon.com/Tenura-75378-0001-Fabric-Non-Slip-Netting/dp/B008528S1I/ref=sr_1_4?ie=UTF8&qid=1482910452&sr=8-4&keywords=anti%2Bslip%2Bmaterial&th=1
Offline ArchDill
« Reply #2 on: Wed, 28 December 2016, 01:41:34 »
Perfect! I think I might have some of this at work. Thanks so much!
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #3 on: Wed, 28 December 2016, 15:22:20 »
as ghetto as it sounds, I have had some great success with a few packing peanuts squished between the PCB and the case.
-Dana
