Author Topic: What are the dimensions of Gons Tkl mounting plate?  (Read 1703 times)
Offline hgoel89
« on: Wed, 28 December 2016, 13:03:24 »
I have been trying to find out the plate design for gon tkl, but it's no where to be found.
Can someone share the Gons tkl plate dimensions in mm x mm
I plan to make some modifications on phantom plate to accommodate the difference in top row distance.
Sent from my ONE A2003 using Tapatalk
Offline hgoel89
Re: What are the dimensions of Gons Tkl mounting plate?
« Reply #1 on: Wed, 28 December 2016, 21:36:50 »
Bump
Offline diqkiq
« Reply #2 on: Sat, 31 December 2016, 13:47:19 »
There was a  skeleton plate gb that was meant for the Phantom a while back. But it turns out that it actually fit the Gon and winkeyless pcbs. Try a search in the gb for the thread and ask the OP for the CAD files
Sent from my Nexus 6 using Tapatalk
Filco Majestouch TKL, Noppoo Choc Mini, Realforce 87 55g, Model M TKL, Ducky Shine 3 TKL, KC60, Planck.
