Author Topic: Does anyone know what these keyboards are worth?  (Read 2364 times)
Offline cwenos
« on: Fri, 30 December 2016, 20:03:27 »
I have just stumbled upon a large amount of old mechanical keyboards including 7 XL/Datacomp keyboards. I have been able to find information on the IBM model M's that I have but I have not been able to find any information on these particular keyboards. On the front of the keyboard it says it is  XL/Datacomp and the model is LX-122-US Part number: 901025-50 Date 05-09-1994. I would appreciate any information if anyone knows, thanks!
Edit: Here are the pictures of the board http://imgur.com/a/gknjo
« Last Edit: Fri, 30 December 2016, 22:00:22 by cwenos »
Re: Does anyone know what these keyboards are worth?
« Reply #1 on: Fri, 30 December 2016, 21:52:47 »
If they have mechanical switches then they may be worth something.
If they are membrane/rubber dome keyboards then they are probably trash.
If they have interesting switches or high-quality keycaps then they are usually worth more.
What kind of connector does it have? Is it AT, XT or even PS/2?
Please do take a picture of the keyboard and post. You can attach images to posts on this forum.
Offline cwenos
« Reply #2 on: Fri, 30 December 2016, 22:01:21 »
I just edited the original post with links, thanks!
Offline y11971alex
  • Looking for Toronto meetup
« Reply #3 on: Sat, 31 December 2016, 08:13:20 »
That looks like a rebranded Model M.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Sat, 31 December 2016, 08:41:16 »
Pretty sure they're Lexmark OEM Model M122s made for Datacomp. Judging by the caps they're probably buckling springs.
« Reply #5 on: Sat, 31 December 2016, 17:59:44 »
Lexmark manufactured the Model M keyboards for IBM in the early '90s. In 1996 Lexmark's machines were taken over by Unicomp who still makes the keyboards.
The "Model M" moniker refers to the construction, not to the layout. The most common layout is the one with 101 keys for sure, but there were also those without numeric keypad and these big 122-key keyboards.
Unfortunately, these "battleships" are the least desirable types because they are so big, and the later-made keyboards are often less desirable because they are often made with thinner plastic and metal than the early ones.
You can often find the going sales price for an item on eBay if you have the right search term and check "Sold listings". From what I can see, the price is about half that of a 101-key Model M.
