Author Topic: MAD-MAX themed keyboard! Need help with keycaps  (Read 3182 times)
Offline hgoel89
« on: Sun, 01 January 2017, 09:02:29 »
I have a crazy idea to make a mad max inspired keyboard.
I plan to have a skeleton plate for top and bottom, and give them a rusted pattern.  Then use the sack cloth to cover the open sides.
Using orange/red led for fire style underglow.
Now I am stuck at keycaps.
Are there any existing brown translucent keycaps?
I am open to other options.
I plan to use a brown gateron
Sent from my ONE A2003 using Tapatalk
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: MAD-MAX themed keyboard! Need help with keycaps
« Reply #1 on: Sun, 01 January 2017, 09:51:00 »
I don't think there are. Maybe you would be better off buying a white set and making them really dirty? See Pexon's post about his Fallout 4 themed 60% build. :D
Album of it here - https://imgur.com/a/tEi8N
« Last Edit: Sun, 01 January 2017, 09:53:29 by katushkin »
« Reply #2 on: Sun, 01 January 2017, 13:07:01 »
I did a pseudo-rustic version but did not alter the key caps.
A dirty/stained/bloody dye job would be easy with PBT caps, use plastic tape for dye-resist areas and markers or paint markers for "damage".
- D Trump 2026-10-24
Offline hgoel89
« Reply #3 on: Sun, 01 January 2017, 21:59:55 »
That's a nice build.
But it has a lot more keys. What pcb/board have you used? Or is it all self wired?
EDIT: I have found the info on that keyboard.
« Last Edit: Sun, 01 January 2017, 22:02:37 by hgoel89 »
Offline 1391406
« Reply #4 on: Mon, 02 January 2017, 00:26:36 »
There's this. You'd need to buy the entire board, though.
« Reply #5 on: Mon, 02 January 2017, 08:34:32 »
It is not a "build" it is a Model F 122-key terminal without the plastic case shell. I did not change anything electrical, I only added a Teensy.
