Author Topic: Soldering Thread: SMT edition  (Read 4472 times)
Offline pineapple
  • I'm a sentient pineapple who likes electronics.
« on: Sun, 01 January 2017, 16:23:26 »
A general soldering thread plus a question of my own.
How do you guys solder your SMT components?
Do you use a toaster oven as a reflow oven? or do you use a soldering iron, some flux and solder?
I personally want to read some insight before I tackle my first attempt at soldering SMT components. I've only done some soldering
with through-hole components on an arduino shield and on a GPIO male header on a raspberry pi zero.
Anyways, I'm anticipating some great responses!
P.S. Happy New Year!
Offline pineapple
Re: Soldering Thread: SMT edition
« Reply #1 on: Sun, 01 January 2017, 17:36:35 »
sorry, wrong board. My bad
Offline ghostjuggernaut
« Reply #2 on: Sun, 01 January 2017, 17:44:34 »
I solder surface mount using a normal iron+station.  What I do is place a little bit of solder on one of the pads, and then reheat it and place the component on.  Ill then solder the other pad, and reflow the first pad last.  It seems to work pretty well, but there may be a better way of doing it.
Offline Parak
« Reply #3 on: Sun, 01 January 2017, 17:49:31 »
Depends. If it's a one-off prototype/project/repair, I'll hand solder it. More than that, especially if it's dual sided, I typically can't be bothered and just send it off to a fab :D
Hand soldering methods vary depending on components. HASL finished boarts are a bit easier to work with as you can tack down parts before applying solder, unlike ENIG. For very small passives like 0402, I use 0.4mm tipped MFR-H4-TW tweezers. Leaded ICs with small pitch of 0.5mm or thereabouts I use a special concave Pace tip for drag soldering. QFNs and similar I pretin the pads then use hot air. No clean flux is always required, and often the more the better. I like NC-559-V2-TF as long as one is careful to get the genuine article.
Technique does matter more than gear, but having quality gear helps a lot and makes the process easier and less error prone.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #4 on: Mon, 02 January 2017, 20:32:11 »
No worries.  I've moved it to the Making Stuff Together! sub-forum.
Offline pineapple
« Reply #5 on: Mon, 02 January 2017, 21:44:53 »
Thank you so much. Happy New Year!
Offline vvp
« Last Edit: Tue, 03 January 2017, 03:43:49 by vvp »
