Author Topic: [ErgoDox] Case for PCB Mount  (Read 2132 times)
Offline layornos
« on: Mon, 02 January 2017, 07:05:30 »
Hi all,
i am searching for a 3D printable case for my ErgoDox, but the only one i can find are for plate mounted switches with holders for the switches.
But i have a board with already soldered switches, and now i need a printable case. Does anyone got one for me? :D
Offline climbalima
  • likes building stuff
Re: [ErgoDox] Case for PCB Mount
« Reply #1 on: Mon, 02 January 2017, 11:44:07 »
I do actually. I have to find it though. Will update you
Sent from my SM-G920V using Tapatalk
Offline layornos
« Reply #2 on: Mon, 02 January 2017, 18:06:09 »
Thank you!
Offline climbalima
« Reply #3 on: Wed, 04 January 2017, 21:07:32 »
https://drive.google.com/file/d/0B8_E3ktJLo4SRkRZcDlDa04tbGM/view?usp=sharing
Its a huge file for what it is. I took the normal dox stl and cut it into slices. I then removed the switchplate slice and extended it.
