Author Topic: SwitchTop Removal tool: Anyone tried 3d printed ones by shapeway?  (Read 5439 times)
Offline Phenix
Did anyone tried these tool?
http://www.shapeways.com/product/ZLA6MAESE/switch-opener?optionId=56097936&li=marketplace
I have an pair of pliers (similar to mk.com ones), but it takes long to open one switch..
Wondering if these are easier to use
Winter is coming.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: SwitchTop Removal tool: Anyone tried 3d printed ones by shapeway?
« Reply #1 on: Tue, 03 January 2017, 10:51:11 »
That looks good.  I'll order one when I place my next Shapeways order and report back here.
 - Ron | samwisekoi
Auto-typed by my GH-122 keyboard.
Offline devoi
« Reply #2 on: Tue, 03 January 2017, 11:31:36 »
I have one and it works great, especially if you're trying to modify a bunch of switches in the least amount of time possible.
Offline Phenix
« Reply #3 on: Tue, 03 January 2017, 11:43:06 »
Yea, the design looks promising..
@sam: any idea around when that is?
Winter is coming.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #4 on: Tue, 03 January 2017, 14:39:11 »
This week or next.  I'm prototyping a GH-122 case for the 2017 builds, and will add this to my first order for that.
- Ron | samwisekoi
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #5 on: Tue, 03 January 2017, 14:48:39 »
I bought one a year or two ago, and it worked good for me.
There's already a old thread about it somewhere.
Just be careful.  Someone (sorry I can't remember who) was saying that they can damage the little plastic clip/tabs on the switches. Although,  none of mine were damaged.
I eventually just went back to using my metal Beast tools.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #6 on: Wed, 04 January 2017, 17:14:04 »
I did a bunch of springs with my Beast tools, and after a while...
Anyhow, I'm interested in this design, so I just ordered one from Shapeways.  I'll advise on how I like it once it gets here and I give it a good run.
 - Ron | samwisekoi
Offline Jeu
« Reply #7 on: Wed, 04 January 2017, 19:46:48 »
do you push the switch bottom end first into it and catch the top housing as it pops off? seems awkward to use.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #8 on: Wed, 04 January 2017, 20:31:50 »
Yeah, that's how it works.
If someone had some made out of better materials I would probably use mine more.
« Last Edit: Wed, 04 January 2017, 20:33:39 by CommonCurt »
WTB/WTS/WTT ---->
Offline Phenix
« Reply #9 on: Thu, 05 January 2017, 13:49:34 »
they are used from the bottom side!?
I thought they would clip in from the top (like the mk.com tools.........)
Winter is coming.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10 on: Fri, 06 January 2017, 17:28:35 »
Yes, this tool is designed to open the switch from the bottom.
You place the switch on top of it like in my picture.
WTB/WTS/WTT ---->
Offline Phenix
« Reply #11 on: Fri, 06 January 2017, 18:03:55 »
Ok..
Then it isnt that useful for me.
hopefully someone will produce something similar, but aith use from the top (so while switches soldered in)
Winter is coming.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #12 on: Fri, 06 January 2017, 18:21:52 »
Ok..
Just like pressing down a pair of Beast tools with perfect synchronization.
Mine is on order; I'll fiddle around with that useage as a goal.
Just tried with my Beast tools -- how could that work?  They come up from underneath the tangs.
(I admit I do not mod switches in place, so maybe I am just missing something obvious.)
 - Ron | samwisekoi
« Last Edit: Fri, 06 January 2017, 18:31:27 by samwisekoi »
Offline Phenix
« Reply #13 on: Fri, 06 January 2017, 18:38:47 »
More talking about if one wants to change spring weight/stem after soldering..
for beforehand these tools should be great
Winter is coming.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #14 on: Sun, 08 January 2017, 00:56:16 »
It seems like a good design and could be pretty easy to make from any number of square pipe/tube and some ingenuity. i remember someone making a tool from a binder clip. I think it was on Youtube i saw it?
-Dana
Offline childofthehorn
« Reply #15 on: Sun, 08 January 2017, 01:10:08 »
Haha tiny flathead screwdriver or plastic pry tool will do just fine in a mounted switch. Never had one break, even RGB tops (bought extra JIC and not needed). You can get said screwdriver set at any dollar store.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #16 on: Sun, 08 January 2017, 01:12:08 »
If someone had some of these made out of aluminum I'd definitely get one.
It be a lot smoother if it were made out of aluminum.
One of the only gripes I have with the one from shapeways is that it's that rough 3D printer material.
WTB/WTS/WTT ---->
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #17 on: Sun, 08 January 2017, 01:19:18 »
Here's another old pic from when I ordered mine a while back.
WTB/WTS/WTT ---->
Offline OfTheWild
« Reply #18 on: Mon, 09 January 2017, 02:34:10 »
seems like it would be fairly straight forward to cast from resin as well.
-Dana
Offline FrostyToast
  • Litshoard
« Reply #19 on: Mon, 09 January 2017, 02:42:23 »
Zeal had one made from metal as well as plastic; both from Shapeways.
You should probably ask him about the difference.
Quote from: elton5354
