Author Topic: LZ Trikr Software Crash  (Read 2348 times)
Offline YoungMichael88
  • HHKB Wannabe
« on: Tue, 03 January 2017, 13:59:36 »
Is anyone else having trouble running the Trikr software with windows 10? I can't get the damn thing to open without crashing after 2 seconds. Any help would be great. I've tried running in windows 8 compatibility mode and also tried to "repair" it using the installer. It's the latest version from LZ. I've completely uninstalled and re-installed, I've restarted the computer, nothing works.
Offline dgneo
  • Supervillain
Re: LZ Trikr Software Crash
« Reply #1 on: Tue, 03 January 2017, 14:01:46 »
What version are you using YM? I've got Windows 10 as well, and Ver:14.02.14 stays open fine.
I also don't have a board to plugin and be detected by it, but on its own it seems to be working.
  • HHKB Wannabe
« Reply #2 on: Tue, 03 January 2017, 14:15:18 »
Do you happen to have the .zip file I could use. The zip LZ sent me says TRiKer R1.4.3
  • HHKB Wannabe
« Reply #3 on: Tue, 03 January 2017, 14:16:15 »
The software opens when my keyboard is not plugged in. As soon as I plug it in, it crashes
Offline dgneo
  • Supervillain
« Reply #4 on: Tue, 03 January 2017, 14:18:56 »
Ah so mine is an older version it looks like (R1.2.1), but give it a shot!
  • HHKB Wannabe
« Reply #5 on: Tue, 03 January 2017, 14:20:50 »
Just tried. Same issue on both versions. Hmmm
Offline henz
  • What?
« Reply #6 on: Tue, 03 January 2017, 15:30:37 »
i threw my trik pcb in the trash. Or maybe i gave it away. Dont remember.
