Author Topic: [GB] M65-A | Made with RAMA.WORKS (Complete)  (Read 1785519 times)
Re: [GB] M65-A | Made with RAMA.WORKS
« Reply #3000 on: Mon, 18 December 2017, 10:33:34 »
Mine was sent out on the 29th of Nov and arrived today. Despite my board being one of those caught up in the delay having now assembled it and using it as of now I can say this board is, without doubt, worth the wait of any delay.
Like the monochrome theme going on there! Seeing all these post with people saying, "It's totally worth the wait", doesn't make the waiting any easier though.  It just makes me more excited and impatient!
Offline Kavik
« Reply #3001 on: Mon, 18 December 2017, 17:12:07 »
Dang, that looks nice and clean. What switches did you put in it?
Offline wongie
« Reply #3002 on: Tue, 19 December 2017, 03:04:44 »
Unlubed cherry clears with 62g SPRiT springs for the alphas, same for the mods except I used cherry tactile greys to colour match the grey granite caps. Don't know why I colour matched them when you can't even see them :))  oh well at least i'll know.
« Last Edit: Tue, 19 December 2017, 03:07:38 by wongie »
Offline Malenky
« Reply #3003 on: Tue, 19 December 2017, 08:37:43 »
Last update was a week ago, could you give us an idea of when you'll be shipping over the holidays? I assume you'll be taking some time off.
Offline sixdeuces
  • DIYKeyboards.com
« Reply #3004 on: Tue, 19 December 2017, 15:36:49 »
Mine showed up today! Sadly, one corner of the box is slightly crushed (thanks, FedEx) but the contents all seem fine.
Offline aneasyusername
« Reply #3005 on: Tue, 19 December 2017, 16:15:01 »
Mine showed up today too! Box was fine, but there seems to be a small bit of discoloration in the finish on the top of the case. I'd much rather have a crushed box.
Offline SakeJams
  • HAPPINESS ONLY REAL WHEN SHARED
« Reply #3006 on: Tue, 19 December 2017, 16:16:50 »
A E S T H E T I C
Offline pixelpusher
« Reply #3007 on: Tue, 19 December 2017, 16:47:13 »
Looks like it's going to be right at 1 year to get this board.  Not happy.
Offline Dodgy
  • I specialize in bird law.
« Reply #3008 on: Wed, 20 December 2017, 01:04:06 »
Just unboxed mine, beautiful. Jchan, shooting you an email regarding my plate.
Hi, what's your favorite color?
I'm making keycaps, take a look if you give a damn.
Sale Thread
Offline Auxo
  • Formerly CJD_Anthony
« Reply #3009 on: Wed, 20 December 2017, 03:18:05 »
Some quick pix of my M65-A, built with the help of Adam.
**oops, looks like a couple of pictures got flipped. oh well lol
« Reply #3010 on: Wed, 20 December 2017, 15:54:36 »
swell flipped pic better than flipped keeb amirite
Offline Valaris
« Reply #3011 on: Thu, 21 December 2017, 20:03:32 »
First time soldering question: If I accidentally soldered a switch into the wrong hole (regular caps lock vs stepped caps lock for example), technically that switch is the only one I need to desolder to replace it? I don't need to desolder everything do I?
« Reply #3012 on: Thu, 21 December 2017, 20:10:40 »
Nah, just that one switch and you will be good to go
Sent from my LG-H918 using Tapatalk
Offline Brammm87
« Reply #3013 on: Fri, 22 December 2017, 14:22:59 »
I got around to building my M65-A today. I sadly ended up making some costly mistakes. Luckily, in the end everything works as expected.
Photos here: https://imgur.com/a/kfZkg
pls gief bbv2
Offline Malenky
« Reply #3014 on: Fri, 22 December 2017, 14:37:40 »
We have (at this point) 60 outstanding units to ship out.
Just packed a dozen more just now.
53 / 448 are left.
Numbers don't really make sense, but I'm guessing 12 or so a week go out. Which means that's 2, sometimes 3 a day. Are they not in pre-cut foam and purpose-made boxes?
Either way, I assume we're around 50 units left to ship. At this rate, accounting for stopping for holidays, I presume shipping will finish early February. Is this about right?
« Last Edit: Fri, 22 December 2017, 14:39:48 by Malenky »
Offline Jedi
« Reply #3015 on: Fri, 22 December 2017, 16:00:03 »
Beautiful keyboard pics!  and nice build log, really great that you kept in the pictures about the steps you needed to consider in addition.  No doubt this is very helpful to others for their builds.  Great job :thumb:
« Reply #3016 on: Fri, 22 December 2017, 16:04:46 »
Nice build Brammy good thing you got it turned around in the end~!
@people; I have a QMK /PCB related question. Today when I turned on my PC I noticed two pairs of keys had switched. I have a split backspace with backslash programmed on the left key 1u and backspace is where backslash usually is. My bottom row has a 6.25u space and starts with Control, Win, Alt. Win and Alt were somehow swapped today as well as backspace and backslash. I cleared the EEPROM and make'd and reflash a fresh .hex file which somehow fixed the swapped backspace and backslash. Win and Alt were still swapped. I reconfigured the keymap.H file to swap K41 (previously Win) with K43 (previously Alt) and now the keys are all back in the right order. It makes it a bit confusing though for example I will probably forget the next time when I edit the keymap. Has anyone ever had this happen, and know how to reset or fix this? I think it might have happened during a PC reboot cycle as I also had an issue with the underglow not turning off when the PC was off.
Offline duynguyenle
  • Personal text? What personal text???
« Reply #3017 on: Fri, 22 December 2017, 17:00:56 »
Never had this happened to me before, are you using OSX or Windows? This sounds a little bit like OSX's behaviour when you flip the modifiers around in the system settings. But I don't own a Mac, so this is purely conjecture.
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
« Reply #3018 on: Fri, 22 December 2017, 17:12:29 »
Thanks for the reply and good point, didn't even think to check whether it is OS related. I just checked on a different PC (both windows) and my reprogrammed keys act the same so I don't think it is the OS.
Offline yottagray
« Reply #3019 on: Fri, 22 December 2017, 19:32:35 »
Mine finally arrived. Hooray for early Xmas presents! Unfortunately, I won't have time to get it clacking just yet with the holiday rush, but so happy to see it there on me shelf waiting for me.
Sad to see that the anodizing was scratched though before I even got it out of the box.  :(  On the bright side it's on the rear of the board so I shouldn't see it too often.
Check out some pics of the beefy (and beautiful) packaging: https://imgur.com/a/h3A3P
Offline cooperred
« Reply #3020 on: Fri, 22 December 2017, 23:57:00 »
Anyone else bootmapper pcb keeps on disconnecting and connecting back randomly?
Probably a dumb question, but did you try a different usb cable?
Sorry probably should've included some information. Tried 3 different USB cables and 2 computers. Pretty sure its the pcb.
I would email keyclack support.   You probably need a replacement.  I’m sure it’s fixable but will require some troubleshooting and proper equipment.
Did you test it before you built it?
If you want to take close up photos of the back of the PCB we can take a look here.
Oh yeah it was working for months and all of a sudden issues started happening. Didn't spill water or anything like that.
Did you figure it out? Mine does the same thing, except it's brand new. It's like it sometimes(most of the time) doesn't feel like turning on.
Offline cooperred
« Reply #3021 on: Sat, 23 December 2017, 00:11:35 »
My Page Down, Page Up, Insert, and Delete don't register in the ps2avrgb bootmapper. Anyone know what's up with that?
Offline pixelpusher
« Reply #3022 on: Sat, 23 December 2017, 01:14:36 »
any update on the 50 unshipped boards?
Offline pon10
  • looking at my keycaps..
« Reply #3023 on: Sat, 23 December 2017, 05:36:01 »
+1
This is almost starting to get very ridicules regarding information and promises.
Offline Madēo
« Reply #3024 on: Sat, 23 December 2017, 06:09:48 »
+1
An update would be appreciated.  :thumb:
Offline Darknight00z
« Reply #3025 on: Sat, 23 December 2017, 07:42:11 »
The delay is indeed getting out of hand. Not an exact comparison, but VicG's silent black had 96k switches to sort through and got them done in a week.
« Reply #3026 on: Sat, 23 December 2017, 09:45:28 »
Bad comparison. He just had to count out switches.
And there were proxies, so he didn't even have to count all 96K
« Reply #3027 on: Sat, 23 December 2017, 11:40:06 »
If you want to keep that comparison going you would be fine with the brass weight missing and maybe a couple of screws too, as the MX Black switches shipped with some scratchy Red springs.. and I'm pretty sure I'm missing a switch or two in the baggy.
Offline Tally810
« Reply #3028 on: Sat, 23 December 2017, 14:20:23 »
Let's be real here j Chan has had these boards for 5 months so I don't think time has been an issue.  These people that are still waiting deserve their boards soon as they have been pretty damn patient.  That being said I did receive my board and everything looks great.
Offline jjwax
« Reply #3029 on: Sat, 23 December 2017, 16:27:45 »
This is by far the best board I have ever seen.
The group buy has been very disappointing, to say the least.  Delays in GBs are expected/inevitable, but the lack of communication and missed promises are ridiculous
Offline kolashnikov
« Reply #3030 on: Sun, 24 December 2017, 07:39:49 »
Same thing happened to me once or twice. It appears that bootmagic is being activated somehow by accident, since my symptoms match all the "features" that bootmagic provides (https://docs.qmk.fm/feature_bootmagic.html). I have a theory that it is somehow related to the keyboard being unplugged, but haven't done any tests because it's a minor annoyance to clear and flash.
« Reply #3031 on: Sun, 24 December 2017, 09:03:18 »
Thanks so much, that sounds very plausible! I wasn't able to reset it before though, I am using QMK toolbox in windows to flash. How did you manage to undo the swap with a reset and reflash? I will program these commands on a layer somewhere so I can unswap if it happens again.
Flashing the new hex file unswapped everything somehow, but I programmed keys in a third layer to unswap keys if needed in the future. Hope it works, this is my layout (with the code in properties): http://www.keyboard-layout-editor.com/#/gists/f415c3cafd81d2191c2daa5536aa7e6d
« Last Edit: Sun, 24 December 2017, 09:51:29 by a clacktical mistake »
Offline kolashnikov
« Reply #3032 on: Sun, 24 December 2017, 11:36:30 »
Sounds like you got it resolved, but I'll try to answer your question and elaborate a little bit more.
First, I had to reset the eeprom using the instructions here:
https://github.com/qmk/qmk_firmware/tree/master/quantum/tools
That is, erase and overwrite with the "eeprom_reset" hex file provided in that folder of the repository. After that, I flashed my own JC65 keymap again and the swapped keys were back to normal. Note that I did all of this from a linux terminal so I don't know how/if these translate to Windows.
Having those keys to unswap in the future is the best solution I can think of. Since all the bootmagic keys were activated together in my case, it might be possible to program a macro that toggles all the bootmagic options with a single button. It could be easier than undoing them all individually.
« Reply #3033 on: Tue, 26 December 2017, 14:04:08 »
Two weeks since the last update. Got any good news for the 53 of us still waiting, JChan?
Offline pon10
« Reply #3034 on: Tue, 26 December 2017, 14:30:07 »
Last update i got was this on a email from 7/6/2017
Hello M65-A Supporters,
I'm glad to say that the M65-A bulk order has clear customs, and we're on our way to getting these into your happy fingers.
Offline kustom3
  • bonjour
« Reply #3035 on: Tue, 26 December 2017, 14:45:24 »
Here's my build log for my M65-A.
My best to the people still waiting for their keyboard.
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #3036 on: Tue, 26 December 2017, 14:48:52 »
Awesome build log :)
Offline sixdeuces
  • DIYKeyboards.com
« Reply #3037 on: Tue, 26 December 2017, 15:01:08 »
Excellent! Thanks for sharing!
Offline Kafka
  • i like clean things
« Reply #3038 on: Tue, 26 December 2017, 15:03:54 »
/r/bestof
Offline kawasaki161
« Reply #3039 on: Tue, 26 December 2017, 17:17:41 »
Sweet baby jesus. At the calendar scene I thought this was just another post complaining about wait times, but I was pleasantly surprised.
How many days did it take you to make that?
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #3040 on: Tue, 26 December 2017, 17:18:30 »
this is the best build log ever made
Offline Rumblehotep
« Reply #3041 on: Tue, 26 December 2017, 18:53:49 »
/wipes tear
Offline kolashnikov
« Reply #3042 on: Tue, 26 December 2017, 18:58:26 »
This happened to me again tonight for no apparent reason. I tried to program a macro to disable all of the swaps at once, but couldn't get it to work. I was able to make a macro that activates all the swaps, but the same method wouldn't toggle or turn them off again.
Another solution that disables all of the toggles is to use another bootmagic feature to clear the eeprom. I enabled bootmagic [put "BOOTMAGIC_ENABLE=yes" in rules.mk] and flashed my keymap again. Now, when I hold space + backspace while plugging the board in, it clears the eeprom. All the bootmagic features are disabled at once and there's no need to re-flash after that.
Here's what I had going for the macro in case anyone else wants to take a stab at it. Changing all the false flags to true allows me to reproduce the issue, at least.
bool process_record_user(uint16_t keycode, keyrecord_t *record) {
    if (record->event.pressed) {
        switch(keycode) {
            case UNMAGIC:
              if (!eeconfig_is_enabled()) {
                eeconfig_init();
              /* keymap config */
              keymap_config.raw = eeconfig_read_keymap();
              keymap_config.nkro = true;
              keymap_config.swap_control_capslock = false;
              keymap_config.capslock_to_control = false;
              keymap_config.swap_lalt_lgui = false;
              keymap_config.swap_ralt_rgui = false;
              keymap_config.no_gui = false;
              keymap_config.swap_grave_esc = false;
              keymap_config.swap_backslash_backspace = false;
              eeconfig_update_keymap(keymap_config.raw);
              clear_keyboard(); // clear to prevent stuck keys
              break;
Offline MythicalWagyu
  • Poor Impulse Control
« Reply #3043 on: Wed, 27 December 2017, 00:30:17 »
If I were to run a group buy in the future I would make sure kustom3 got a kit in exchange for one of these glorious gifs..... just saying  :thumb:
KEYBOARDS >>
MICE >>
COMPUTER >>
Offline Madēo
« Reply #3044 on: Wed, 27 December 2017, 07:15:01 »
Can we please get an update, this is getting really infuriating   :mad:
Offline Malenky
« Reply #3045 on: Wed, 27 December 2017, 07:48:17 »
If it took one hour to pack and book shipping for a single person's order, this group buy has 53 hours left of actual work, assuming no more have been packed since the last update. Being generous, let's say 60 hours. This group buy could be wrapped up in the next four working weeks if 3 hours a day were spent on it.
If this is not reasonable, please could you provide some explanation or reason for delay, or perhaps a reasonable/realistic timeline for what is happening with my hundreds of dollars I spent a year ago?
Offline Aesomatica
« Reply #3046 on: Wed, 27 December 2017, 17:16:18 »
On day 1, he packed and shipped 29 boards. This could be over in 2 days of good, solid work.
My suspicion is that there are problems with the remaining boards, and that he is waiting for replacements.
Because if it isn't that, the only other explanation I can think of is that he is too depressed to send them out.
In any case, three emails to support@keyclack.com and multiple posts I've made here have gone unanswered.
I love Rama's design, but this has been pretty poorly handled in terms of customer support and transparency.
Offline pon10
« Reply #3047 on: Wed, 27 December 2017, 17:27:11 »
Haaha this made my get a smile instead of looking into this thread with the wrath :rolleyes: Especially frank! forgot about that episode ;D
Awesome log, beautiful board  :) cant waiiiit to get it in, IF IT HAPPENS  :-X
Offline energyd
« Reply #3048 on: Wed, 27 December 2017, 20:48:16 »
Guys, tried to flash my M65 qmk pcb and encountered a weird behavior:
The KC_ESC and KC_GRV key are somehow swapped.
Spent like two hours to figure that out! Any idea?
« Reply #3049 on: Wed, 27 December 2017, 21:14:54 »
Did you try switching them in the firmware?
