Author Topic: [GB] M65-A | Made with RAMA.WORKS (Complete)  (Read 1784837 times)
Offline naut
  • Aerospace Engineer
Re: [GB] M65-A | Made with RAMA.WORKS
« Reply #850 on: Wed, 29 March 2017, 11:50:34 »
Neither board is compatible as far as I know.
Oh, that's sad!
Time to practice my soldering skill then...
Hmm... given that soldering is a must, is it possible to use a different PCB with the kit? Otherwise, is it possible to pick up more PCB's for the kit after the gb has shipped? It would suck to spoil the pcb ...
Learn to Solder Kit: Hue
https://www.amazon.com/dp/B01GDTHTAK/ref=cm_sw_r_cp_api_b682ybHHKNJFE
:P I am an electrical engineer by trade, although it's been quite awhile since I did any soldering. Time to hit the irons again to practice haha
;) It'll come back fast then.
I'd still need more spare PCB's just in case lol.  :))
Lol.You can actually order the JC65 pcb's on keyclack.com already.
https://www.keyclack.com/product/jc65-pcb/
Offline johnthedong
« Reply #851 on: Wed, 29 March 2017, 12:24:41 »
Oh, that's sad!
Wait whatttt!  ;D Thanks again - putting in an order shortly!
Offline johnthedong
« Reply #852 on: Wed, 29 March 2017, 12:44:32 »
Just reviewed the dxf file for the pcb - the dimensions of the holes are ~38mm across so it seems to be way larger than the the specifications of the holtites here: https://www.digikey.com/catalog/en/partgroup/holtite-series/26789 . Gotta put the solder to the metal again!
Offline cynviloq
« Reply #853 on: Wed, 29 March 2017, 13:11:54 »
.38mm or 38mm? 38mm is definitely wrong....
Offline johnthedong
« Reply #854 on: Wed, 29 March 2017, 13:19:21 »
Interesting, the online DXF viewer gives me 38mm. (http://imgur.com/PPPIqg9) If it's .38mm the holtites might actually work...
Offline kustom3
  • bonjour
« Reply #855 on: Wed, 29 March 2017, 17:32:49 »
.38mm would also be wrong, you need more than twice that to fit a Cherry MX switch pin.
Offline johnthedong
« Reply #856 on: Wed, 29 March 2017, 20:10:58 »
Yeah, both numbers are weird. I don't have my autocad laptop with me right now as I'm outside, but I'll take a look next week on that to see if the dimensions are that. I also have an order of holtites coming in so hopefully this works with the final product :)
Offline breusch91
« Reply #857 on: Wed, 29 March 2017, 20:25:09 »
Please refer to my last post. This was already solved and I already posted a fact checked sheet from another source as to holtites compatibility. Unless this pcb changes they will not work.
« Last Edit: Thu, 30 March 2017, 08:07:35 by breusch91 »
Offline imprevade
« Reply #858 on: Thu, 30 March 2017, 14:08:57 »
What kind of support will we get for the QMK PCB? Will it come flashed with a default layout? Will the QMK repository be updated with matrix, keymaps, config, etc for the M65-A? If so, when?
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #859 on: Thu, 30 March 2017, 16:04:29 »
My guesses:
Assuming that Jack accepts the pull request, the QMK support would likely be done before the PCBs ship. Worst case you'd have to grab a fork of QMK.
Yes. It's almost unheard of for PCBs to go out without a default layout pre-flashed  :thumb:
Offline imprevade
« Reply #860 on: Thu, 30 March 2017, 16:18:53 »
My guesses:
Awesome, that's exactly what I wanted to hear. I already have QMK forked, and I've been studying it hard—I'm just trying to plan for how much I'll have to do on the back end before I'm able to start using my M65.  ;D
Offline Malenky
« Reply #861 on: Fri, 31 March 2017, 16:39:07 »
Is the original timeline still accurate by the way? If not, what's the latest?
Offline ghostdeini
« Reply #862 on: Fri, 31 March 2017, 17:42:11 »
Jchan posted last week (link) that these are expected to come in April, right around the time he is moving to a bigger office space. From a production standpoint, it sounds like they are right on schedule! Choo choo!
Offline dyoungc
« Reply #863 on: Fri, 31 March 2017, 18:33:50 »
Does anyone know if holtites will be compatible with the QMK PCB?
Offline johnthedong
« Reply #864 on: Fri, 31 March 2017, 19:47:04 »
No, as per the discussion a few pages ago. I've also asked jchan directly via discord. No holtites unfortunately. *looks at pack of holtites*
Offline dyoungc
« Reply #865 on: Fri, 31 March 2017, 23:42:36 »
Does that apply to both the standard JC65 PCB by winkeyless as well as the QMK version?
They were designed and manufactured separate from one another, and QMK seems to be pretty new. Does anyone have the QMK PCB specs yet?
Offline johnthedong
« Reply #866 on: Sat, 01 April 2017, 00:01:24 »
According to the information I've gathered from multiple sides, I think it's both. I asked jchan directly about the qmk pcb. Not entirely sure about the Jc65 but from information from other people here I think it's a no too. If it fits holtites I'd be pretty happy though.
Offline johnthedong
« Reply #867 on: Sun, 02 April 2017, 15:33:42 »
Figuring something out atm, and am wondering what kind of aluminum does the M65-A use?
Offline jchan94
  • Keyclack Inc
  • * Moderator
  • Please email jchan@keyclack.com. PMs are disabled
    • KeyClack
« Reply #868 on: Mon, 03 April 2017, 17:41:56 »
Made with RAMA from RAMA.WORKS, the M65-A is fully reprogrammable, has underglow, allows for backlit LEDs, and features an ALU6061 rigid body frame design.
I just got the production box and the foam is so nice! These will be packed very nicely.
Support Email: support@keyclack.com
Did you miss something from us?
- Sign up for our Mailing List: https://eepurl.com/coAJ5r
Offline forevermadrigal
« Reply #869 on: Mon, 03 April 2017, 17:49:50 »
Mmm it's April  ;D hope the move is going smooth
Offline imprevade
« Reply #870 on: Mon, 03 April 2017, 20:57:59 »
MY BODY IS READY
Offline johnthedong
« Reply #871 on: Mon, 03 April 2017, 21:36:06 »
OMG! Any box design spoilers?
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #872 on: Tue, 04 April 2017, 19:04:13 »
Probably will take photos of it tomorrow. Gotta take my m65-a apart to make it look good.
The box uses a lot of foam, and custom cut outs for each part. These will be packed like this from the manufacturer -> to me -> to you.
When I get the shipment, I'll open each box and check the contents to make sure the order is yours, and QC/QA them. Then if its good, pack it into a box and get it out to you :).
Offline johnthedong
« Reply #873 on: Tue, 04 April 2017, 19:43:49 »
Sounds great!
Offline leoparder
« Reply #874 on: Wed, 05 April 2017, 03:08:48 »
Dear jchan, I am now with 4 emails unanswered for the qmk. I am still waiting for an updated invoice to pay the 18 usd. Can you please check ? Thank you !
Sent from my iPad using Tapatalk
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #875 on: Wed, 05 April 2017, 03:20:11 »
Can you bump it? Not sure where it is.
Jchan@keyclack.com just in case.
Offline Jedi
« Reply #876 on: Wed, 05 April 2017, 06:37:12 »
There wasn't at the time of order an option to purchase a second switch plate. I upgraded to brass and I would also like to try the aluminum switch plate or if possible add a second brass plate. I pm'd on reddit but wanted to post here to ask.
Is it possible to get a second switch plate?
Also, like everyone else, the wait is SO worth it for this GB. Thanks Keyclack.com and Rama for all the work put into this GB :thumb:
« Last Edit: Wed, 05 April 2017, 06:38:43 by cswanic »
Offline rioc
« Reply #877 on: Wed, 05 April 2017, 07:34:06 »
weeeeeee... is end of April, early May still accurate for shipping?
can't wait to see the awesome box and the awesomer keeb sitting inside it  ;D
« Reply #878 on: Wed, 05 April 2017, 09:54:56 »
2nd'ed  ^-^
Offline Valaris
« Reply #879 on: Wed, 05 April 2017, 09:56:43 »
For those asking to see what the box looks like, Rama posted a picture of it last week on his Facebook.
Offline rmendis
  • Artisan addict
« Reply #880 on: Wed, 05 April 2017, 10:45:38 »
 If anyone is interested in selling their M65 or spot, please PM. Thanks!
Offline imprevade
« Reply #881 on: Wed, 05 April 2017, 11:22:55 »
They want to see the box, Rama posted a picture of the foam insert.
Offline johnthedong
« Reply #882 on: Wed, 05 April 2017, 11:50:22 »
^+1. So hyped for this still!
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #883 on: Wed, 05 April 2017, 12:11:03 »
Missed this, gorgeous board
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #884 on: Wed, 05 April 2017, 15:17:27 »
This should be about right. Please remember I'm moving offices end of April so they might be chilling for a little while!
I hear things are a tad behind, due to the recent holiday in China. The delay should only be up to 4 days. But other than that, I think we should get this tracked to me in about 2 weeks.
Offline Tally810
« Reply #885 on: Wed, 05 April 2017, 15:41:14 »
Whoa looks like I need to start ordering switches and stuff.
Sent from my SM-G928V using Tapatalk
Offline pr0ximity
« Reply #886 on: Wed, 05 April 2017, 15:54:33 »
Just got some of the new Blacks from SwitchTop, feeling pretty smooth. I think they'll pair nicely with the M65  ^-^
Offline Kavik
« Reply #887 on: Wed, 05 April 2017, 16:01:31 »
Get with the program, man! Jk, I got switches a month or two back, but I'm going to be waiting on keycaps for quite a while. I'm in the SA 1965 GB, but I'll be missing a 1.75u right shift since I based my order around a full sized board at the time. I really wanted to put GMK Nautilus on this, but that GB hasn't even started yet  :(
Offline Tally810
« Reply #888 on: Wed, 05 April 2017, 16:09:34 »
Lol yea I have some switches at the house I could use but if I don't put zealios in it i will be cheating myself
Offline dubious
  • 쏘쿨
« Reply #889 on: Wed, 05 April 2017, 16:12:43 »
this news bodes well for the Exent gb... ( ͡° ͜ʖ ͡°)
Offline johnthedong
« Reply #890 on: Wed, 05 April 2017, 16:32:25 »
Got in my R5 65g zealios and have pulse/ gmk carbon sets waiting for it! Now I just need a tsafox kit lol.
Offline imprevade
« Reply #891 on: Wed, 05 April 2017, 21:16:33 »
165001-0
I have all my parts ready—just need M65!
Offline pixelpusher
« Reply #892 on: Wed, 05 April 2017, 22:34:09 »
Gateron greens, nice!  what color LEDs?
Offline imprevade
« Reply #893 on: Wed, 05 April 2017, 23:13:14 »
Gold!
Offline johnthedong
« Reply #894 on: Thu, 06 April 2017, 19:08:39 »
:D waiting for photos of the packaging!
Offline rioc
« Reply #895 on: Fri, 07 April 2017, 04:54:07 »
yeah same, and we're not good at waiting ;P
Offline kmba
  • Formerly tameone
« Reply #896 on: Fri, 07 April 2017, 07:43:21 »
I want to see the packaging that the sample packaging gets packaged in.
keyboards.
Offline squeakypizza
« Reply #897 on: Fri, 07 April 2017, 12:29:37 »
Is there any recommendations as to which LED's I should get for the underglow and switches?  This would be my first build with LED's.
Offline Tally810
« Reply #898 on: Fri, 07 April 2017, 12:54:23 »
Underglow will have smd rgbs already installed.  For in switch leds I say get 1.8mm leds.  Just pick your color and go with the water clear brightness as the diffused ones I have gotten in the past are pretty terrible
Offline geldnite
  • under₩₩₩ater
« Reply #899 on: Fri, 07 April 2017, 14:40:42 »
if anyone wants to sell me their silver + nylon base order, please pm!
super upset i missed out on this. :(
tada-68       xmit-87
