Author Topic: Does GMK and JTK alpha legends line up well with each other?  (Read 2418 times)
Offline madn3ss795
« on: Thu, 05 January 2017, 18:47:07 »
Specifically I'm using JTK Stormtrooper and want to put these GMK caps on my board.
Edit: I meant whether the position and size of the legends are the same, instead of bigger/smaller or being a few milimeters off.
« Last Edit: Fri, 06 January 2017, 00:49:46 by madn3ss795 »
Offline ghostjuggernaut
Re: Does GMK and JTK alpha legends line up well with each other?
« Reply #1 on: Thu, 05 January 2017, 19:40:41 »
They are both cherry profile, but just to be sure I put a few of my stormtrooper caps on my board with GMK hyperfuse.  They matched as far as i can tell.  I don't have a way of measuring them to be sure, but I doubt you would notice a difference if there is any.
