Author Topic: Filco Zero question  (Read 2318 times)
Offline pfink
Filco Zero question
« on: Fri, 29 January 2010, 18:47:55 »
Is it possible to tell if a Filco Zero keyboard has Fukka or XM switches without popping off a keycap? For example, do Zeros with serial numbers less than xxxxx have XM switches and those greater have Fukkas?
Thanks.
« Last Edit: Fri, 29 January 2010, 18:51:56 by pfink »
Offline ch_123
Filco Zero question
« Reply #1 on: Fri, 29 January 2010, 19:08:21 »
If they were manufactured before a certain point last year, then they are XMs for sure. When they switched to Fukkas, the part number of the XM ones gained a '-Y' suffix. However, it does not say this on the box, and I'm not sure if the labels have them either as they are supposedly just b-grade stock keyboards sold at a lower price.
Offline maxlugar
Filco Zero question
« Reply #2 on: Fri, 29 January 2010, 23:42:58 »
Quote from: pfink;154686
Thanks.
No, there is no reliabile way to tell the difference other than popping off the key caps and comparing what you see with the detailed pics of each switch type that have been posted here.
Emperor of the IBM 84-key AT Model F Darkside
Offline vils
Filco Zero question
« Reply #3 on: Thu, 04 February 2010, 03:50:04 »
My Filco Zero is marked ALPS FKB108Z/JB-AB (W EB064),
it has black sliders. Any ideas of which variant this is?
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
