Author Topic: Need Help ! Model M stop registering some keys after Nut and Bolt mod.  (Read 1685 times)
Offline Tangtawan
Hello,
This is my first time doing nut and bolt mod on the Model M. Its a 1987 SSK. After I reassemble the board together, I tested every key and all seems to register without a single issue. However, I left the computer on for 15 mins and as soon as I come back I found that some keys were not registering anymore; so I use Auqa's KeyTest and it shown that two vertical rows did not register. The keys seems to click just find though, just that it wont register, what should I do? and is this common problem after bolt modding? (pic in attachment)
Thanks.
« Last Edit: Sat, 07 January 2017, 17:19:06 by Tangtawan »
My boards : Model F AT (6450200), Industrial M (1394950), Model M SSK (1391472), Model M13 (13H6705), Model M (1390131), Focus FK-2001 (ALPS SKCM Blue), HHKB Pro 2, Realforce 87U 55g, KBP V80 Matias Click, TADA68 (Gateron Reds), Filco Majestouch 2 TKL (67g Ergo Clears), Cherry G80-11800 (Ergo Clears), KBT One 108 (MX White), Ducky One TKL RGB (MX Black), Filco Majestouch Tenkeypad (MX Brown), Leopold FC210TP (MX Red)
Re: Need Help ! Model M stop registering some keys after Nut and Bolt mod.
« Reply #1 on: Sat, 07 January 2017, 17:53:18 »
I do not know the precise answer to your question, but here is a tangent that may be significant:
The tightening of the bolts determines the pressure between the plates. I recommend the same pressure on all the screws, and "looser-rather-than-tighter" as the first option for adjustment.
Is it possible that the screws in that area are tighter or looser than the others? I recommend loosening all of them at least half a turn, then slowly adjust until they all feel the same.
- D Trump 2026-10-24
Offline mike52787
  • Alps Aficionado
« Reply #2 on: Sat, 07 January 2017, 17:53:48 »
Heres some really easy things to try,
loosen or tighten the bolts in the affected area
clean the connections on the end of the ribbon cables
Offline Tangtawan
« Reply #3 on: Sat, 07 January 2017, 18:08:20 »
Thanks for all the comments. I did an experiment and found a weird problem. As soon as I took off the top cover, all the keys registered again; but as re install the top cover- the same row stop registering again. Is it possible that the membrane trace on the ribbon cable is kinking and loses contact? Before bolt modding, I was able to put all the ribbon cable inside the case without a problem, but after bolt modding i can no longer shove all of them inside, so i need to shove it manually and might causing it to kink? Its confusing how bolt modding will affect the length of the ribbon cable.
« Last Edit: Sat, 07 January 2017, 18:20:48 by Tangtawan »
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Sat, 07 January 2017, 20:37:12 »
This is almost certainly an issue with the tightness of the bolts or the ribbon connector. Kinking the ribbon shouldn't matter, but it might not be properly seated. Also, make sure the bolts are roughly equally tight. Don't go overboard with tightening them, but don't have them loose either.
Offline lemur
  • personal text
« Reply #5 on: Sat, 07 January 2017, 22:19:33 »
I did a bolt mod on a board and I had a similar problem.
I ended up testing the membrane with a electrical meter and found that in the process of completing and tweaking the bolt mod one of the contacts on the ribbon cable had degraded to the point where it just wouldnt work anymore.
i think a replacement membrane is under $20 from unicomp, if you determine that is the issue.
its my suggestion: test for continuity for all the leads on the ribbon cable.
edit: oops you mentioned its an SSK..... maybe a bit harder to get a membrane for one of those! good luck
« Last Edit: Sat, 07 January 2017, 22:21:58 by lemur »
keyboards
