Author Topic: Are these cheap PBT anygood?  (Read 3620 times)
Offline FinancialWar
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
Re: Are these cheap PBT anygood?
« Reply #1 on: Mon, 09 January 2017, 17:27:49 »
Can't see how thick/thin the are, but they're probably pretty cheap. Some people prefer thinner caps, most will prefer thicker. The feel is just a bit different.
You might be happier going with one of the below sets from Massdrop
NPKC Blank PBT Keycaps
Backlit Doubleshot PBT Keycap Set
Tai-Hao Sweet Tooth PBT Keycap Set
