Author Topic: KC60 Reprogramming Problem  (Read 1648 times)
Offline Harms
« on: Wed, 11 January 2017, 23:10:05 »
Hi everyone
I'm using TMK to reflash the KC60 However, I keep getting the error "did you forget to press the reset button". The thing is I cannot even find a reset button on my PCB. Also I'm flashing it as GHPad boatloader atmel dfu as the instructions state on the key chatter guide.
Any help would be appreciated thank you.
« Last Edit: Wed, 11 January 2017, 23:14:19 by Harms »
Offline obviouslygene
Re: KC60 Reprogramming Problem
« Reply #1 on: Fri, 13 January 2017, 01:28:43 »
There's button at the bottom of the pcb, should be accessible through a window in the case.
That's your reset switch.
Offline Harms
« Reply #2 on: Fri, 13 January 2017, 03:32:17 »
Hello
Yes I ended up jumping a pad at the bottom right for reset. Thanks a lot for the input I appreciate it.
