Author Topic: Plate mounted vs PCB mounted Stabilzers  (Read 28930 times)
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« on: Fri, 13 January 2017, 01:53:57 »
hello everyone,
I just received my rs68 kit from Massdrop and i got too excited so i started doing mock ups
Then i noticed the stabilizers they came with are total garbage so i decided to buy some
after searching i found out that the cheapest source i can find for various stabilizers would be from http://www.switchtop.com/products (im not advertising or anything but they are indeed the cheapest i can find with shipping CONUS)
So im confused whether to get plate mounted or pcb mounted ones
Im not sure if my plate does infact accept plate mounted ones, but i just need legit stabilizers that would feel much much better.
are costar stabilzers an option for rs68?
let me hear your thoughts before i press checkout  :thumb:
Offline RageNorge
Re: Plate mounted vs PCB mounted Stabilzers
« Reply #1 on: Fri, 13 January 2017, 02:51:54 »
Not to hijack your thread, but what even IS the difference between them?
Sent fra min HUAWEI GRA-L09 via Tapatalk
« Reply #2 on: Fri, 13 January 2017, 03:20:09 »
PCB mount clip through the PCB, plate mount clip to the plate.  I haven't noticed any significant difference in feel...
@potatobot post a pic of the cutouts in your plate then anyone who knows can tell you what will fit even if they aren't familiar with the rs68 :)
Offline RageNorge
« Reply #3 on: Fri, 13 January 2017, 03:22:00 »
But, why the difference in stabs? Why not just have the plates be compatible from the start?
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #4 on: Sat, 14 January 2017, 08:50:11 »
hey, sorry it took me so long to reply
im confused where to buy some stabs now. techkeys are offering some which are made by GMK too
here's the pic of the plate (sorry it has some switches/stabs mounted on for fitting)
« Last Edit: Sat, 14 January 2017, 08:53:20 by potatobot »
Offline Badwrench
  • ummmm.....I forgot
« Reply #5 on: Sat, 14 January 2017, 09:10:13 »
Looks like you need pcb mount.  The plate is cut larger to clear the stab housing.
Can you pull one of yours out and get a picture?  I can't quite tell what they sent you.  Switch top does seem to be the cheapest for a full set.
Offline Tactile
« Reply #6 on: Sat, 14 January 2017, 09:15:55 »
What's the problem with the stabs included with the kit?
REΛLFORCE
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #7 on: Sat, 14 January 2017, 09:30:27 »
according to this photo, the stabs are FAKE and they are really wobbly. Aside from that, i need a 7U wire which MD forgot to include. :(
im too lazy to tear it apart now, but i already confirmed that the plate doesn't allow for plate mounting.
I was leaning towards techkey's offering because they say its "made by GMK"
Offline Tactile
« Reply #8 on: Sat, 14 January 2017, 09:41:17 »
I received some similar stabs in something I bought - either in a kit or bought separately. Mine were also already clipped - or, really, just weren't made with the little tab at all, so no need to clip. I wouldn't use the word "fake" to describe them, though. They're just aftermarket stabilizers. Anyway, I've had no trouble with any Cherry type stabs I've ever used. Once the cap is installed they all work great.
I've built 2 40%, a GH60 rev C, and a Clueboard, all with Cherry type stabs and somewhere in that bunch are some aftermarket stabs similar to the ones in your photo but I wouldn't be able to find them by typing on the keyboards.
REΛLFORCE
Offline kawasaki161
« Reply #9 on: Sat, 14 January 2017, 09:44:18 »
The stabs on switchtop are the exact same as the ones you have right now (chinese clones), so you only have to get the 7u one for the right wire there.
The Techkeys ones are legit, but the 6.25u wire does not work with plates if you would want to use it for a different build.
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #10 on: Sat, 14 January 2017, 09:47:45 »
Thanks for the info! Im only getting 7u & 2u's for my build so no worries.  :thumb:
Its just that i need a 7u for my build which wasnt included in my package.
So now im looking for the best stabs i can get, wanna try out the legit ones too, as my previous experience with those kinds of stabs weren't that good at all(they get removed from the pcb when i try to remove keycaps). Toothpick mod would be a good fix but they are just too flimsy for my taste.
Offline Tactile
« Reply #11 on: Sat, 14 January 2017, 09:50:59 »
Another thing to keep in mind is that you don't want the stabs to be tight and precise. You want them to be a bit of a sloppy fit so if you have a cap (usually a spacebar) which is slightly warped or a little out of spec you can still install it and it will work fine. If the stab inserts were as precise as the switch stems you'd have a lot more trouble fitting some keycaps and then they might bind somewhere in the stroke. IOW, they're sloppy for a reason.
REΛLFORCE
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #12 on: Sat, 14 January 2017, 09:53:04 »
Ohh thanks! im going with techkey's offering then, to test them out and compare them. :D
i only have plate mounted ones on my ducky and pok3r to compare with the china stabs for now.
Offline chuckdee
« Reply #13 on: Sat, 14 January 2017, 10:48:27 »
I just completed an RS78. They are PCB mount, and I was told the same thing about the included stabs, so used the ones from a prior buy that I'd gotten in on... for once buying on spec worked out!  And I will add, make sure you test them before starting your soldering.  And by test I mean take the mounts, and move them up and down to make sure that they work.  I didn't, and didn't figure out what people meant by test until after I'd soldered and they didn't work. :(  That's a really bad feeling, and very hard to fix.  I only fixed it for my spacebar.  The others, I just cut the mounts off with a wire snipper.
« Last Edit: Sat, 14 January 2017, 11:06:52 by chuckdee »
Offline menuhin
« Reply #14 on: Sat, 14 January 2017, 11:24:13 »
It is quite clear that the stab on the left has both hooks and holes for screws, and the one on the right has only the holes for screws.
Doesn't it make some difference?
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
