Author Topic: About VA68M LED Brightness  (Read 20466 times)
Offline qkdxorjs1002
« on: Fri, 13 January 2017, 11:37:27 »
Is there way to modify PWM values in firmware for LED Brightness??
I want more bright LED than stock VA68M... :confused:
« Last Edit: Fri, 13 January 2017, 11:40:09 by qkdxorjs1002 »
Offline Varmilo MNF
  • * Moderator
Re: About VA68M LED Brightness
« Reply #1 on: Tue, 11 April 2017, 03:30:36 »
Hi, you think the current LED brightness is not enough when you set it at maximum?
This is hard to change from firmware.
Offline smartties
« Reply #2 on: Wed, 26 April 2017, 17:07:42 »
Hi,
I would be also really interested on my VA68m ( changing the breathing mode pattern ).
Thank you
