Author Topic: Can anyone with an old g80-1800 help a brother out?  (Read 2320 times)
Offline mike52787
  • Alps Aficionado
« on: Fri, 13 January 2017, 15:01:47 »
so far, restoring my g80-1838HPU was going really well, but every project I do, I seem to **** up somewhere. This time, my mistake was desoldering the cable and forgetting how it was soldered in. Can someone provide me with a photo like the one attached, but showing the cable and the wire colors? Thanks for the help in advance.
« Last Edit: Fri, 13 January 2017, 15:13:37 by mike52787 »
Offline jerue
  • (Whenever that happens :P)
Re: Can anyone with an old g80-1800 help a brother out?
« Reply #1 on: Fri, 13 January 2017, 16:55:23 »
edit:
so if the board is facing you, from closest to furthest
yellow, white, green, black, ground/thick black (this is closest to the edge of the case).
« Last Edit: Fri, 13 January 2017, 17:37:16 by jerue »
Offline mike52787
  • Alps Aficionado
« Reply #2 on: Fri, 13 January 2017, 17:46:32 »
edit:
Thank you so much!!!! <3
