Author Topic: question about sip sockets  (Read 1514 times)
Offline pixelpusher
« on: Sat, 14 January 2017, 03:26:43 »
I know there are lots of posts and guides about sip sockets for leds, but I'm not seeing an answer to the questions I have.  So, the switches are in, and I am able to open them from the top.  I have some switch opening tools that make it fairly easy :)
Then, I put the sips in and close the switch back up.  BUT... now how do I go about soldering the sips?  They are kinda wobbly and have about .5 or 1mm of play within the housing.  So, when I turn the PCB over, the sips drop down about .5mm or so.  I'm afraid that if I solder them in that way I might end up with my leds sticking up too high, causing interference with keycaps.  I can put an led in there but it doesn't really solve the problem.
Anyone have tips/tricks?
Also, how do you know which leg of the led is positive/negative once you snip it to put in the sips?
Offline henz
  • What?
Re: question about sip sockets
« Reply #1 on: Sat, 14 January 2017, 03:41:48 »
put in the sips, close the switch, put in the led. hold it while you solder.
