Author Topic: Switch blockers to cover switches of a keyboard - how?  (Read 4846 times)
Offline menuhin
« on: Sat, 14 January 2017, 08:15:31 »
I received a bunch of switch blockers from Pimpmykeyboard for covering up unused key locations of a Tipro keyboard.
It works aesthetically - the blockers held the switch stem in a pressed down position with its top leveling at about the lower edge of an installed key cap.
However, it meant all those keys under the blockers are pressed and held down.
I didn't know what will happen, so I plugged in my pre-programmed Tipro keyboard. After about 2 seconds of flashing its indicator LEDs, its scream as loud as a smoke detector.
How should I use these switch blockers properly so that the keyboard can work like normal when have them installed?
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline Phenix
Re: Switch blockers to cover switches of a keyboard - how?
« Reply #1 on: Sat, 14 January 2017, 09:43:27 »
Maybe set the blocked keys to do nothing?
Winter is coming.
Offline mike52787
  • Alps Aficionado
« Reply #2 on: Sat, 14 January 2017, 10:46:13 »
desolder the switches underneath and make sure the pins aren't making contact with the pcb
Offline menuhin
« Reply #3 on: Sat, 14 January 2017, 11:16:55 »
It is a Tipro 128, and I'm not ready to desolder any switch on it, as it currently serves as a ortholinear layout whiteboard for me.
For these keys with the switch blockers on, I have not assigned any function to them in the 'ChangeMe' layout editing package, and normally pressing them when plugged in wouldn't trigger anything.
IBM M13 black
HHKB Pro 2 HasuBT
Offline PollandAkuma
« Reply #4 on: Wed, 01 February 2017, 16:35:10 »
Hey Freund! I have a Tipro too :D what layout are you using?
Offline menuhin
« Reply #5 on: Wed, 01 February 2017, 16:55:27 »
Perhaps like this?
Before I have all my Space Cadet 'Round 7' (?) caps, I have some of my DSA Granite caps and other DSA caps there.
IBM M13 black
HHKB Pro 2 HasuBT
« Reply #6 on: Wed, 01 February 2017, 17:52:34 »
Perhaps like this?
Wow, 3u caps... I currently have a qwertz layout with numpad, and random cashier things on top. I'm planning to change it to a planck layout, or a Terminus mini. The thing that bothers me is the heaviness of using two switches to one cap, may need to swap the springs out, which is awfully troublesome. And the caps...
Offline menuhin
« Reply #7 on: Wed, 01 February 2017, 18:02:27 »
Perhaps like this?
Swapping springs is relatively easy, compared to lubing or desoldering. I didn't plan to swap springs because 2u POS are actually not that heavy at all, but 3u POS keys are really quite heavy.
I found these 3u POS space bar caps only from 7bit, an perhaps those that fit on Filco Minila are similar too. For 2u caps but not necessary in space bar profile, I'm able to get quite some color and profile options on Pimpmykeyboard.
IBM M13 black
HHKB Pro 2 HasuBT
