Author Topic: Soarer's expert help needed  (Read 3118 times)
Offline Tactile
« on: Sun, 15 January 2017, 12:31:27 »
I'm working with a Soarer's PS/2 to USB converter. I have a need to recognize a special key combination: a Function key & a letter. F9 + C, for example.
I've looked through the docs and it seems that this capability simply isn't there. I see key combinations with one key being a modifier, but not two "regular" keys. I was hoping someone here could prove me wrong.
REΛLFORCE
Offline ShawnMeg
Re: Soarer's expert help needed
« Reply #1 on: Sun, 15 January 2017, 13:48:12 »
Can you use F9 as a function layer, so that F9 + C will register whatever you'd like?  In the example below, I set F9 as a function key for function level 1.  By holding down F9 + C, the calculator app will open.  I don't know if Soarer's will allow macros that don't include a modifier.  Someone else more experienced can respond.
Code: [Select]
layerblock
    FN1 1
endblock
remapblock
    layer 0
    F9 FN1
endblock
remapblock
   layer 1
   C MEDIA_CALCULATOR
Endblock
IBM Model F122 X 2 internal Soarer's || IBM Model M122 internal Soarer's || AEK II SKCM Salmon ALPS external adb_usb converter ||  AEK M0115 SKCM Orange ALPS click mod external adb_usb converter || AEK M0115 SKCM Salmon ALPS external adb_usb converter ||
Offline Tactile
« Reply #2 on: Sun, 15 January 2017, 14:15:20 »
Code: [Select]
layerblock
    FN1 1
endblock
remapblock
    layer 0
    F9 FN1
endblock
remapblock
   layer 1
   C MEDIA_CALCULATOR
Endblock
What a marvelous idea. I'll give that a try. At least now I have something to try - I was stumped. Many thanks.
REΛLFORCE
Offline Tactile
« Reply #3 on: Sun, 15 January 2017, 14:23:27 »
Yep. More testing required but that does seem to do exactly what I need. Thanks, again, ShawnMeg!
REΛLFORCE
Offline Tactile
« Reply #4 on: Sun, 15 January 2017, 15:31:11 »
It all seems to be working great. Thanks again, ShawnMeg, for helping me turn this into the coolest keyboard on the planet!
157684-0
REΛLFORCE
Offline ShawnMeg
« Reply #5 on: Sun, 15 January 2017, 17:51:59 »
Glad to be of help.
