Author Topic: Keyboard Lubricant  (Read 4248 times)
Offline trievalot
Keyboard Lubricant
« on: Sun, 31 January 2010, 05:25:53 »
Not sure if this has been discussed in a single thread before.....
What do you suggest as a lubricant for sticky keys? I tried first of all electric shaver lube on a couple keys and it worked OK, but had a "smell" to it. Then i remembered i had silicone spray i bought to loosen up vertical blind tracks and it worked great! (i got this from Spotlight - a local habedasher)
Anyway - it had loosened the sticky keys (shift and enter) and it feels like my NIB model M again (did this to a M)
Ill let you know if it stops working!
[SIGPIC]
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
Keyboard Lubricant
« Reply #1 on: Mon, 01 February 2010, 14:07:19 »
If you get key binding problems on a Model M, it's usually time to inspect things a little more closely. You may have cracks in the plastic, or broken rivets.
While my silicone spray treatment didn't do much for my Model M RShift in the long run, I have successfully used it on a Cherry G81 (as you may read in another thread here).
« Last Edit: Mon, 01 February 2010, 14:09:27 by keyb_gr »
