Author Topic: XDA profile?  (Read 10673 times)
Offline skuko
XDA profile?
« on: Fri, 20 January 2017, 08:01:15 »
so what do you guys think about it?
yes i'm implying the new MiTo set on MD, but i want your opinions about the profile. i have a couple of DSA sets at home (the OG granite and macross among them) but i stopped using them, because i felt that that the gaps between the caps are too large, especially for gaming.
seeing that this profile has a bit larger top surface are and thus a bit steeper cap walls, it could be the ideal mix between SA (way too high for me) and DSA...
what do you guys think?
Offline mustardgreens
Re: XDA profile?
« Reply #1 on: Fri, 20 January 2017, 09:46:13 »
I actually like the small pads on DSA. It's less comfortable, but I find I'm more accurate with it.
XDA looks alien to me, and based on looks alone I don't have much interest in it.
Re: XDA profile?
« Reply #2 on: Fri, 20 January 2017, 09:48:16 »
The only DSA set I have and ever will have is Granite, and...I actually like typing on it on my Jane. The Jane has a rather wide angle, so the flat keys aren't as bad as on a flatter board.
Going to try and get on the Canvas set if I can. I'm sure it won't be much different in terms of typing angle.
Offline zslane
Re: XDA profile?
« Reply #3 on: Fri, 20 January 2017, 12:26:18 »
I really like the shape of these XDA keycaps.
Can't really comment on their texture until we type on them. Can't comment much on colors since we've only seen a very limited color range between the two keysets released so far (Milestone and Canvas). Since they are uniform R3 there's not much else to say about them, really.
Offline kmba
  • Formerly tameone
Re: XDA profile?
« Reply #4 on: Fri, 20 January 2017, 12:35:29 »
Slightly higher then DSA with a little bigger patch and I expect to like it better. Waiting on my XDA milestone set. Non sculpted are good for filling strange and small boards!
keyboards.
Offline Niomosy
Re: XDA profile?
« Reply #5 on: Fri, 20 January 2017, 12:52:13 »
I'm curious about them but am waiting it out for a set that appeals to me.
Offline zslane
Re: XDA profile?
« Reply #6 on: Fri, 20 January 2017, 12:59:40 »
Same here.
Offline mniels
Re: XDA profile?
« Reply #7 on: Fri, 20 January 2017, 14:12:54 »
I am actually kind of digging the canvas set.  Apparently so are a lot of other people, 1983 sold so far with 11 days left....
Offline zslane
Re: XDA profile?
« Reply #8 on: Fri, 20 January 2017, 14:18:22 »
I think that's the novelty factor at work (not novelty as in novelty keycaps, but novelty as in its the first XDA set people are seeing).
Offline Niomosy
Re: XDA profile?
« Reply #9 on: Fri, 20 January 2017, 16:25:32 »
This set may appeal to others.  It doesn't appeal to me.  I'm sure an XDA set will come along that I like.  If so, I'll likely buy it.
Offline kmba
  • Formerly tameone
Re: XDA profile?
« Reply #10 on: Fri, 20 January 2017, 17:06:03 »
This is the third (or 4th?) XDA set I'm aware of. Milestone being the first. I bought into that because I wanted a subdued gray/white set with blue and red mods and thought the profile would work nicely on compact boards where it may be a hassle to deal with sculpted rows. Plus, XDA has molds for every conceivable spacebar size.
keyboards.
Offline zslane
Re: XDA profile?
« Reply #11 on: Fri, 20 January 2017, 17:26:24 »
Milestone was probably very popular with folks who liked Granite and missed out on the real thing.
Offline Niomosy
Re: XDA profile?
« Reply #12 on: Fri, 20 January 2017, 17:26:31 »
Yup, the initial runs have been pretty mellow colorways which, if I'm spending money on caps, aren't really my thing.  They're the caps that came with the keyboard I bought and will soon be replaced.  We're really talking personal preference, though.  I'm waiting for stuff like Troubled Minds, Skeletor, and Dasher/Dancer type colorways while others like more mellow colors like gray and beige.
