Author Topic: Model M 1994 Issue  (Read 3904 times)
Offline chase
Model M 1994 Issue
« on: Sun, 31 January 2010, 19:38:00 »
My Model M I found at my local school won't work properly. I'll plug it in, and the caps lock and scroll lock key (Keys I was pressing before it stopped working, flash for a second, followed by a quick numlock flash, then the keyboard powers off. I've tried it on numerous of my systems to no avail. Anyone have any idea whats going on? Maybe I need a new cable? I'm in the dark here.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
Model M 1994 Issue
« Reply #1 on: Sun, 31 January 2010, 20:04:15 »
Perhaps worth asking...are you plugging it into a PS/2 port while the computer is running?
If so, you need to reboot for the port to become active (assuming nothing was plugged into it at last startup). The LEDs will do the powerup sequence even if the keyboard can't send data.
kishy.ca
Offline patrickgeekhack
Model M 1994 Issue
« Reply #2 on: Sun, 31 January 2010, 20:25:05 »
Quote from: kishy;155236
Or is the OP using the keyboard with an adapter already? This was how my Dell AT101W behaved when my adapter stopped working. All the lights would come on once and then nothing. After I replaced the adapter, I could use the keyboard again.
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline chase
Model M 1994 Issue
« Reply #3 on: Sun, 31 January 2010, 20:26:08 »
I tried it with my USB to PS/2 Adapter, and a fresh boot secondary system. I have a feeling the wire is torn, because it was working fine up until I shifted the wire a little bit.
And, it was the IT Guys at my school, was never used by students.
Model M 1994 Issue
« Reply #4 on: Sun, 31 January 2010, 20:29:09 »
Quote from: chase;155238
I would still make sure the adapter is not faulty so that you can be sure it's the keyboard. Try another adapter or try another PS/2 keyboard with the same adapter. You need to proceed by elimination. Once you are sure it's the keyboard wire, then maybe you can try replacing the wire, but I don't know how you would do that. I'm not good at things like that. Unicomp may help you there. They do repair Model M. You can ask them to sell you the wire and you can find someone to do the soldering.
Offline chase
Model M 1994 Issue
« Reply #5 on: Sun, 31 January 2010, 20:33:33 »
I've got my black dell AT101w plugged into the adapter right now, the adapter is fine.
BTW, I'm in Ontario to. Location?
Model M 1994 Issue
« Reply #6 on: Sun, 31 January 2010, 20:35:13 »
Quote from: chase;155243
In that case, I would suggest you contact Unicomp and see if you can buy a cable. You will need someone to replace it though.
I'm in KW by the way.
Offline vils
Model M 1994 Issue
« Reply #7 on: Sun, 31 January 2010, 20:36:55 »
Quote from: ripster;155235
 I doubt it's the cable but a quick continuity test will find that out for you.
Welcome!
I suppose it's time to follow Ripster's advice, a continuity test.
Good luck.
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
Model M 1994 Issue
« Reply #8 on: Sun, 31 January 2010, 20:38:35 »
Hey, it's a trio of Ontarians.
Windsor-Essex here.
kishy.ca
Offline chase
Model M 1994 Issue
« Reply #9 on: Sun, 31 January 2010, 20:39:31 »
I don't have a "proper" tool to take it apart. How do you all get yours apart.
Model M 1994 Issue
« Reply #10 on: Sun, 31 January 2010, 20:41:19 »
Quote from: kishy;155248
Windsor-Essex here.
I noticed that :-)
Model M 1994 Issue
« Reply #11 on: Sun, 31 January 2010, 20:42:47 »
Quote from: chase;155249
If the Model M is identical to the Customizer, then you'll need a thinwall socket. I took my keyboard with me to Sears. It was easier than having to buy the wrong socket and then return it.
Offline vils
Model M 1994 Issue
« Reply #12 on: Sun, 31 January 2010, 20:44:49 »
I don't have the proper tools either, the last time I did something like it I used a flashlight bulb, a battery and a some wire with attached sewing needles. Ghetto, but it worked.
Edit: sorry its 4 o'clock in the morning over here, misread your post. Take apart, not tools to test.
« Last Edit: Sun, 31 January 2010, 20:47:26 by vils »
Offline chase
Model M 1994 Issue
« Reply #13 on: Sun, 31 January 2010, 20:53:04 »
I wonder if its better just trading my two black Dell AT101W's for a sealed in box 88 Model M. THe Dell is still pretty comfortable- to type on though, and passes the double shift test. I'm pretty sure its the wire now, because it was working fine before I moved the wire, I don't think its a connection problem on the inside, rather a problem with a short in the middle of the wire somewhere.
Offline didjamatic
Model M 1994 Issue
« Reply #14 on: Sun, 31 January 2010, 21:34:57 »
Quote from: chase;155256
If you don't want to, PM me the person who wants to do the trade and I have some Dells for them.
Offline chase
Model M 1994 Issue
« Reply #15 on: Tue, 02 February 2010, 13:15:49 »
UPDATE:
Getting it fixed for $30 = Shipping from pckeyboard.com. Bonus, they're replacing the internals with Buckling Spring tech rather then the soft touch I have now, but still keeping the same exterior.
Offline ch_123
Model M 1994 Issue
« Reply #16 on: Tue, 02 February 2010, 13:43:41 »
What part number is your Model M?
