Author Topic: [HELP] Tried re-programming a KC60 and now not working...  (Read 1813 times)
Offline ArchDill
« on: Sat, 21 January 2017, 01:46:26 »
EDIT: NOW NONE OF IT WORKS.
I deleted the drivers on the different interface. Thought it would fix it but it broke it even worse...
Any one know how to get the drivers for a KC60 or should I just go ahead and strip it for the plate and switches?
« Last Edit: Sun, 22 January 2017, 23:44:30 by ArchDill »
Offline Tactile
Re: [HELP] Tried re-programming a KC60 and now not working...
« Reply #1 on: Sat, 21 January 2017, 09:10:01 »
You either managed to flash it, in which case you need to work on the programming and re-flash, or you didn't manage to flash it. If you haven't flashed it then it's a hardware problem. You knocked a wire loose or loosened a plug.
REΛLFORCE
Offline ArchDill
« Reply #2 on: Sat, 21 January 2017, 13:08:33 »
It happen after I loaded some driver for it.
Offline ArchDill
« Reply #3 on: Sun, 22 January 2017, 23:44:39 »
Bump
