Author Topic: Looking for Keycool 84 capslock, numlock, scroll lock, and F12 caps  (Read 4091 times)
Offline aviphysics
I am looking for Keycool 84 capslock, numlock, scroll lock, and F12 caps for my Drevo Gramr 84 (basically a keycool 84 clone).
Any ideas where I would find something like that? I am not even sure what the right search terms would be.
Offline aviphysics
Re: Looking for Keycool 84 capslock, numlock, scroll lock, and F12 caps
« Reply #1 on: Sat, 21 January 2017, 13:49:46 »
closest I have found so far is this set, which is out of stock. (though I only need the four windowed keys.)
http://www.banggood.com/84-White-Blank-Set-PBT-Key-Caps-for-Cherry-MX-Switch-p-83642.html?rmmds=search
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #2 on: Sat, 21 January 2017, 14:26:35 »
I have a KC84 but unfortunately in black and not white :(
Have you checked taobao?
Offline aviphysics
« Reply #3 on: Sat, 21 January 2017, 17:27:19 »
For a white Keycool84, this price doesn't look bad (I think the black ones don't use the windowed keys)
Unfortunately
a) I don't need a whole keyboard (just a few windowed caps)
b) It isn't really possible to checkout using the Google Translate version of the website and I don't read what I presume is Chinese (though my wife has a friend that might).
They might have the keycaps I am looking for, but the term (windowed keycap) and variations I can think of don't return helpful results. Someone that can run searches using the correct Chinese terms might be able to help.
Offline katushkin
  • Just the guy
« Reply #4 on: Sat, 21 January 2017, 23:40:32 »
Try taobaofocus. It's a proxy service that lets you search TB in English and sorts out shipping for you too.
Offline aviphysics
« Reply #5 on: Sun, 22 January 2017, 01:10:00 »
That's cool, though I am still not finding a cap set without a board.
I saw some custom windowed caps people made out of standard caps, by cutting a slot and filling it in with epoxy. I might try that, once I find some caps I like.
Offline Dominathan
  • Too many keyboards? Not enough hands.
« Reply #6 on: Sun, 22 January 2017, 13:32:27 »
I have a white keycool 84.  I can try to find those caps somewhere in my boxes
Offline aviphysics
« Reply #7 on: Mon, 23 January 2017, 09:08:21 »
That would be really cool. If you can find them just PM me with an E-mail to send PayPal to and how much.
BTW, what do you currently have on your Keycool 84?
« Last Edit: Mon, 23 January 2017, 13:49:22 by aviphysics »
