Author Topic: [UK] Cherry Keypad G84-4700 PS/2 G84-4700LPBUS-2  (Read 6530 times)
Offline Rajagra
« on: Mon, 01 February 2010, 02:14:14 »
Cherry numpads (5). Remember the PS/2 version is programmable with macros in hardware, so you can use it to store usernames, passwords, simple game macros or whatever. £20 + £3 P&P, or he will take offers.
Offline Rajagra
« Reply #1 on: Wed, 10 March 2010, 10:08:53 »
Not sure what happened to link in above post. But no matter. Here is another auction for these for only £10 including postage. I had to buy 2 at that price. 6 left, just under 2 days to go.
CHERRY G84-4700 PS2 PROGAMMABLE NUMERIC KEYPAD BLACK
To recap programming instructions from another thread:
Programming Cherry 3700/4700 PS/2 or AT number pads.
NumLock 1 Enter (Press and hold in that order, then release.)
Selects normal mode.
Keys work exactly like number pad of full-sized keyboard.
Keys are affected by PC's NumLock status.
NumLock key toggles PC NumLock status.
NumLock 2 Enter
Selects alternative mode.
Number and period keys act like those from main alphanumeric area of keyboard.
Keys are NOT affected by PC's NumLock status.
NumLock key toggles keypad to act as the navigation keys located between main alphanumeric area and numberpad,
i.e. the inverted T arrows and the 3X2 block above it.
In this alternative mode, the period/Del key can be redefined:
NumLock Del Enter cycles through the following functions of the key:
00
000
NumLock 3 Enter
Selects SHIFTED alternative mode.
Number keys act like those from main alphanumeric area of keyboard, but SHIFTED.
Period key sends shifted comma (key to right of M).
NumLock key toggles keypad to act as the navigation keys between main alphanumeric area and numberpad,
NumLock 4 Enter
Macro mode.
Keys send programmed macros only.
Keys unaffected by PC's NumLock status.
NumLock toggles PC NumLock status.
To program a macro:
Hold down NumLock and press the key you want to reprogram. Let go.
Type the keys you want the macro to send.
This has to be done on the keyboard which is plugged into the number pad's pass-through PS/2 port.
Press NumLock to complete programming of macro.
NumLock Minus Enter
Reset all macros and return to normal mode (1).
« Last Edit: Wed, 10 March 2010, 10:12:02 by Rajagra »
Offline carlsmith
Re: [UK] Cherry Keypad G84-4700 PS/2 G84-4700LPBUS-2
« Reply #2 on: Sat, 13 February 2016, 13:33:11 »
I'm so glad you posted this, as the original thread seems to have disappeared, and this is really useful information. I don't know why Cherry don't explain this properly.
I have a pair of these and they're badass. With Keyboard Maestro (OS X), you can assign all sorts of useful automations to arbitrary shortcuts and then program these keypads to input the shortcut. Because you don't need to manually input the actual shortcuts, you can use complex ones that you would never normally be able to even remember. It lets you inject JavaScript into pages, realign windows, jump between applications... just tons of stuff.
You can also set the keyboard shortcuts to use modifiers, but not program the modifier into the keypad, so you can hold different modifiers on the main keyboard, and hit one button on the keypad. Then, each keypad can do different things when CMD is held or CMD+ALT etc, etc.
They use ML switches, so you can't really customise the keycaps, but MLs work well for what I'm using these for, and you can use relegendable caps (they come with four per pad as standard).
Offline TalkingTree
    • My projects
« Reply #3 on: Sat, 13 February 2016, 13:42:47 »
Six years ago.
Offline carlsmith
« Reply #4 on: Sun, 14 February 2016, 10:43:12 »
I'm still glad.
