Author Topic: Missing IBM Model M fasteners on bottom, front side  (Read 1393 times)
Offline Phormio
« on: Tue, 24 January 2017, 21:09:56 »
I recently bought my first IBM Model M keyboard (1391401) on eBay.  I noticed that on the bottom, there are two holes on the front side, near the front corners of the keyboard, that are empty.  It looks like there used to be something in them that isn't there any more.  It looks like I can see the steel backplate through the hole (see attached photo).  The two plastic halves of the keyboard shell come apart a couple of millimeters if you stick you fingernail in the crack between them.
I am worried that the holes are for a fastener that isn't there, but it also seems to me that there would nothing through that hole to fasten to.  Is the hole for a plastic anti-slip pad?  If so, the loss is no big deal.  I have looked at photos of the bottom of other Model M keyboards on eBay, and it looks like there is something in those holes.  On two of the three photos I have looked at, it looks like a plastic anti-slip pad.  In the other, they look like flat metal circles (a fastener, perhaps? Or just a dirty plastic anti-slip pad?).
Is the slight separation of the plastic halves no big deal?  The keyboard seems to work just fine.
Any answers to the above two questions from people more familiar with Model Ms than I am would be appreciated!
« Last Edit: Tue, 24 January 2017, 21:27:22 by Phormio »
Offline invariance
  • ...here with all the other boson's
Re: Missing IBM Model M fasteners on bottom, front side
« Reply #1 on: Wed, 25 January 2017, 03:26:14 »
You are correct, they are for the front 'feet'.
The separation of the casing when assisted (I hope) would be due to one of the internal case clips having been broken off.  Nothing to worry about.
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline Phormio
« Reply #2 on: Thu, 26 January 2017, 10:27:56 »
Thank you!
