Author Topic: [GB]EXENT - 65% made by TARO (In production)  (Read 1289684 times)
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
Re: [GB]EXENT - 65% made by TARO (In production)
« Reply #3300 on: Thu, 12 September 2019, 14:31:43 »
I can run a small batch if you need it. might take a week or two though as I need to troubleshoot my own Exent PCB, accidentally "killed" it when I was doing some routine cleaning. I checked the power side and it is fine but I need to find out why the MCU failed to initialize, worst case changing the MCU and XTAL. Do let me know how your board failed, it may be a trivial fix in most cases.
Also very interested in this
Offline Hedgey
« Reply #3301 on: Fri, 13 September 2019, 08:25:22 »
Also if anyone has an extra bottom in either PC or Aluminum (Blue or Black) I'm highly interested in buying it from you.
"Resellers don't kill the community, auctioneers kill the community. Look at what happened to Diablo 3"
Offline Katanadog
« Reply #3302 on: Fri, 04 October 2019, 01:09:51 »
I have a good pc bottom! PM me and I'll get some pictures taken.
Offline quadcube
« Reply #3303 on: Mon, 07 October 2019, 02:21:03 »
Did you ever end up thinking about this?  I'm interested in 2 PCBs at least, especially if they'd be QMK and NOT BMC
trying to make a small run of 20 units of the PCB (direct replacements for EXENT and 910), just have to figure out how can I start a GB on GH.
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #3304 on: Mon, 07 October 2019, 08:07:26 »
Great to hear! I'd also love to join in on this if still possible.
Offline PancakeMSTR
« Reply #3305 on: Mon, 07 October 2019, 09:37:43 »
I'd also like to get a new pcb as mine is dead
Offline alexfry
« Reply #3306 on: Mon, 07 October 2019, 13:46:04 »
Definitely in x2
Offline merlin64
    • MechMerlin
« Reply #3307 on: Tue, 08 October 2019, 13:28:35 »
Folks, I'll be porting the Exent into QMK tonight 10/08/19
Join in at roughly 7:30 PM PST on https://www.twitch.tv/mechmerlin and hang out =)
Special thanks to Carcha for letting me borrow his Exent.
« Last Edit: Tue, 08 October 2019, 13:54:48 by merlin64 »
Offline PancakeMSTR
« Reply #3308 on: Tue, 08 October 2019, 13:49:14 »
Sweet! Will definitely be curious about this one.
Offline merlin64
    • MechMerlin
« Reply #3309 on: Wed, 09 October 2019, 12:36:55 »
The port is successful and is now available on QMK Configurator
https://config.qmk.fm/#/exent/LAYOUT_65_ansi
Pls report back any problems/issues/comments you may have!
Offline PancakeMSTR
« Reply #3310 on: Wed, 09 October 2019, 21:55:55 »
Thanks for that merlin, legit awesome.
Offline quadcube
« Reply #3311 on: Sat, 12 October 2019, 01:41:38 »
GB is posted, awaiting mod's approval
Offline Riba
« Reply #3312 on: Mon, 14 October 2019, 12:25:31 »
Thanks mechmerlin, you're a star!
Offline eddible
« Reply #3313 on: Sun, 02 February 2020, 11:23:06 »
So my kit arrived mid house move and I’ve only just got round to properly checking. Turns out there’s no screws in the box!  :'(
Could someone let me know the screw type/length that secures  the base to the case, and also the foot to the base?
Offline xondat
  • i'm not a star
« Reply #3314 on: Sun, 02 February 2020, 12:35:24 »
This might help. Search "screws" as it's been talked about quite a bit :)
Mine didn't come with any screws. Does anyone know the screw suzey/length required to attach top and bottom piece?
Weight/foot to poly: M3 x 8mm cap screw
Poly to casing: M3 x 15mm socket head screw
Offline eddible
« Reply #3315 on: Mon, 03 February 2020, 13:07:18 »
Ah, thanks so much!
Offline hottrout
  • I'd Hit Dat Key
« Reply #3316 on: Wed, 19 February 2020, 09:57:30 »
Would anyone be willing to part with one of these keyboards?
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline U47
« Reply #3317 on: Thu, 05 March 2020, 16:07:51 »
If I ever receive mine, I'll keep you in mind.
Offline hottrout
  • I'd Hit Dat Key
« Reply #3318 on: Thu, 05 March 2020, 18:36:32 »
Thank you.
Systems -
  Keyboards -
Offline child
« Reply #3319 on: Fri, 06 March 2020, 15:11:21 »
Thank you.
Well, I'm not completely sure he was serious, so don't hold your breath ;)
Offline Riba
« Reply #3320 on: Tue, 17 March 2020, 23:34:49 »
Anyone in need of some extra plates? I will get some made for myself but if there is interest I can do a few extras. Aluminium/steel, optional powder coating, price should be in $25 range.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #3321 on: Wed, 18 March 2020, 00:38:26 »
For that price, I may be interested in a full aluminum plate. Black, grey, silver or red anodizing is fine. Where are you located?
Offline Vigrith
« Reply #3322 on: Wed, 18 March 2020, 09:50:47 »
Price is attractive, I'd be keen for an aluminium one. I meant to get a PCB when the latest GB ran for that but forgot to, oh well.
Offline Riba
« Reply #3323 on: Wed, 18 March 2020, 12:17:43 »
To clarify, no anodizing on aluminum I am afraid. :(. They only offer powder coating but not sure if that would work on the plate. Tomorrow I am going to visit them for a sample to check if the tolerances and workmanship are acceptable, so more details to follow. Shipping would be from EU.
« Last Edit: Wed, 18 March 2020, 15:37:41 by Riba »
Offline d.caminero
« Reply #3324 on: Wed, 18 March 2020, 14:50:42 »
Please, keep us updated with the plate and your next steps. I'm in EU as well and I could be interested for that price if the result is good.
Offline nephlock
« Reply #3325 on: Wed, 18 March 2020, 15:09:21 »
You should be able to get one exclusives E6.5 pcbs (he’s currently running an order for them). It should fit the exent with a small widening of the base to allow for USB-C
Offline Riba
« Reply #3326 on: Fri, 20 March 2020, 08:26:26 »
A quick update - visited the shop yesterday, they appear more than capable of pulling this off. Good news is that I can actually get the aluminum ones anodized but that will increase the price by a few bucks. I will probably get 10 made, and and get them anodized in black. If someone wants them untreated, let me know. Pics in a few days. Final price to be determined but I expect it to be in $20-$25 range.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #3327 on: Sun, 22 March 2020, 07:20:32 »
I'd probably nab one, but how much is shipping from your location to the US?
Offline Riba
« Reply #3328 on: Sun, 22 March 2020, 08:27:22 »
Well, it would be whatever the actual cost is, $10 at most. Not a fan of the fact that shipping is 1/2 of the item price, so if no one is in a hurry I usually ask a colleague or a friend who happens to be traveling to US to bring it over.
I was supposed to get the sample today but his corona thing is messing things up, I am about the check for the status. I suggest whoever is interested to PM me so we don't clutter this thread (?).
Offline fruitofconfusion
« Reply #3329 on: Sat, 04 April 2020, 01:42:53 »
Maybe I'm missing something obvious, but is that bottom row configuation supported on the Exent? From what I can tell, there are only ever two keys to the left of the arrow cluster before the space bar. Is there a way to modify the layout on QMK for this?
Offline Riba
« Reply #3330 on: Sat, 04 April 2020, 05:19:28 »
Yes, it is supported.
« Reply #3331 on: Fri, 10 April 2020, 19:32:24 »
So I tested my board before soldering via bridging contacts, and all the keys worked. Now I've soldered it and everything except for backspace, pipe, enter, up arrow, and right arrow work. Occasionally when I reflash the board, it will act like right up and enter are all being held down. I've tried reflowing the joints, but given that it's all keys in the same column, i'm wondering if there's an MCU issue. I've checked and no SMD parts are lifted or missing, and I added electrical tape beneath stabilizer screws to make sure nothing is being bridged.
Any ideas?
In addition, when I replug the board, it doesn't immediately register, and I have to go through the 'firm up' step of Catweewee's instructions each time I plug the board back in.
Offline Traveler
« Reply #3332 on: Fri, 10 April 2020, 20:26:46 »
I'm a bit of a noob at troubleshooting, but that would be my first guess. The PCB is notorious for having bad MCU soldering. Is it an original PCB, or one that you got in the recent-ish groupby?
If it's a bad solder job around the MCU, it might look like this:
Here's a map of what pins control which part of the board:
« Reply #3333 on: Sun, 12 April 2020, 16:33:52 »
So with the help of discord, I solved this! A stabilizer screw (on backspace) was shorting the entire column to ground. I wonder if other people have experienced this with screw-in stabs.
Offline loud_asian
« Reply #3334 on: Sat, 18 April 2020, 20:35:31 »
It’s a common issue with screw ins. The fix is usually a nylon or other non conductive material washer.
Offline Captainbuttmonkey
« Reply #3335 on: Mon, 01 June 2020, 12:12:26 »
Seeing as I said I'd let people know how I got on and it's been nearly a year since I said that, here is the first yearly update:
Bit disappointing but not surprising unfortunately
See you all in 2021 for the next update
Offline Traveler
« Reply #3336 on: Mon, 01 June 2020, 13:44:06 »
You can try to PM codywanks. It's a bit of a long shot but he's had some experience with helping to get the boards out, and tends to have good information when we need it most.
If that doesn't produce any results, after waiting another month or two for a response from yuktsi you might want to consider asking for an update in public places such as yuktsi's GB posts and IC posts. It's kind of a d-ck move, but it might be your only hope of getting a response. And other people deserve to know that it appears yuktsi ghosts some of his customers.
« Reply #3337 on: Mon, 01 June 2020, 14:25:57 »
I think I'll probably just leave it, but thanks for the suggestions. Yeh I'm somewhat reluctant to do that, as you say it is kind of a **** move. It's a bit of a difficult one as it's not just a tgr/yuktsi buy but he seems to be the guy that has the boards/the ability to send them out. My understanding is jua essentially disappeared, rama just helped with the design a bit and originative had the keycaps and may or may not have sent them to yuktsi. I do think it's a bit questionable that yuktsi has had other buys going on whilst people have been waiting a very long time for this (and will probably never receive them), but I don't think it would be fair for him to receive all the blame when he seems to be the only person that stuck around for at least some time and tried to send at least a few out. On the other hand running the other buys could have been necessary in order to get some funds to sort out this mess. I think the reality of the situation is it will just fade away and nobody will really care. I highly doubt spreading the word would have any effect on people buying tgr boards anyway, especially as they are nowadays being sold for obscene aftermarket prices.
Offline U47
« Reply #3338 on: Tue, 02 June 2020, 21:09:39 »
I have a nearly identical story. Good communication for a bit, an aramex number provided that never worked, and radio silence since then.
« Reply #3339 on: Wed, 17 June 2020, 16:50:04 »
Yeh I'm not expecting anything but I'll probably check in once a year or so until I forget
Offline r4bbl3d4bbl3
« Reply #3340 on: Wed, 08 July 2020, 13:19:11 »
It's been over 4 years since this was ran, when are extras available?
 ;D
« Reply #3341 on: Mon, 10 August 2020, 23:54:02 »
Wow, I actually found one for sale!
Now does anyone out there have any extra bases they are looking to sell?  :cool:
« Reply #3342 on: Mon, 05 October 2020, 15:15:34 »
Looks like I am the only one using this thread anymore haha.
Hopelessly posting again to see if anyone has a lead on the plate files?
Offline Riba
« Reply #3343 on: Mon, 05 October 2020, 15:22:55 »
Plate files have been posted in this thread. If you fail to find them let me know.
Offline kohalified
« Reply #3344 on: Thu, 22 October 2020, 13:37:22 »
Can I render my keyset on these?
Offline Traveler
« Reply #3345 on: Thu, 22 October 2020, 14:32:31 »
Might want to get in touch with RAMA and ask him. He's the one who designed the board as far as I know. The GB runner, juahenza, doesn't check this thread anymore and I'm not sure if yuktsi does either.
Offline FluffyUnicronz
« Reply #3346 on: Sun, 22 November 2020, 14:22:16 »
Also looking for plate file; previous link is dead.
Offline Riba
« Reply #3347 on: Sun, 22 November 2020, 15:11:53 »
Offline Riba
« Reply #3348 on: Thu, 10 December 2020, 03:36:26 »
If anyone is interested, I'll be making an ortholinear PCB for Exent. IC here:
https://geekhack.org/index.php?topic=110120.0
Offline Havattack
« Reply #3349 on: Fri, 11 December 2020, 11:24:22 »
Do another round! Pretty please...?
