Author Topic: [GB] LZ CLS (Classic TKL) : Finished  (Read 377986 times)
Offline nmur
  • ಠ_ಠ
Re: [GB] LZ CLS (Classic TKL) : Order -> Change order deadline
« Reply #150 on: Tue, 31 January 2017, 21:42:13 »
i don't know how you guys function in Windows without the window key. it definitely looks nicer, but i thought that everyone was just using linux or something
i use win+E, win+M, win+R, win+number row key, win+arrow keys, win+prt scrn, and more on a day to day basis
Offline mech0nly
« Reply #151 on: Tue, 31 January 2017, 21:46:06 »
I prefer grey or black as they go with more sets. Silver only really looks good with classic beige based sets IMO
Totally agree black and silver pair nicely with more sets, but beige + silver looks soo good. What more could you want?
You guys are starting to make me reconsider Winkey...do I need it? I use it... but I want the cool-club look. :cool:
Just remap the winkey lol
Ctrl+Esc, here we come..
we got another one boys 8)
I have gmk olivetti, but confused between gray and silver loool
356mini | 360C | G81-3000SAT | G81-3000SAU | G80-3000LPCXY-2 | G80-3485LWNUS-2
Diamond Polished Cherry Switches!
Offline kconfire
« Reply #152 on: Tue, 31 January 2017, 21:49:13 »
Same here and although some people might think they can do without the Windows key with Ctrl + Esc, the functions you have mentioned are not that frequently used by "average" PC users so maybe that's why people think they will be fine lol
I'm willing to bet many people do not know what the combination of Win+(x) can do except for maybe Win+R which I would guess a lot of people know :D
[Collection] Monokei Kei SE, Realforce R2 TKL, Leopold FC660C
[Soon TM] Monokei Tomo SE, GSKT-00
Offline Cocopah
  • Lurker Extraordinaire
« Reply #153 on: Tue, 31 January 2017, 22:00:32 »
Just remap the key, I personally never use right alt so that gets remapped to winkey (when necessary).
Offline nmur
  • ಠ_ಠ
« Reply #154 on: Tue, 31 January 2017, 22:12:48 »
hm i guess that works. binding it to a two key combination is silly, but you're right in saying that right shift is pretty useless
Offline Hako
« Reply #155 on: Tue, 31 January 2017, 22:14:10 »
Ugh, I can't decide between WKL gray or silver...
Offline kenshinjeff
« Reply #156 on: Tue, 31 January 2017, 22:28:55 »
Hi LZ, is there a way to check what I ordered? Cos I forgot what colour I placed, only remembered the WKL and brass plates, not sure if I got any spares or things like that.
Offline Kev
« Reply #157 on: Tue, 31 January 2017, 22:53:34 »
I agree, but within a keyboard community I figure it would be pretty common knowledge, I think it's just a cool/trendy thing but whatever works for you. I need both L/R Win keys... win+e/r/d/l all day.
Offline maximm
« Reply #158 on: Wed, 01 February 2017, 00:22:15 »
I tried remapping winkey to right ctrl and that worked fairly well.
Offline Puree
« Reply #159 on: Wed, 01 February 2017, 01:50:31 »
take both  :rolleyes:
Offline Fnzzy
« Reply #160 on: Wed, 01 February 2017, 07:04:32 »
Due to my button mapping preferences I only have 3 Keys on the bottom row that I regularly use. Spacebar and both Alts. Then I usually put Win on left Ctrl and Fn on right Ctrl. Seems to be working well so far for me. Now just slap Ctrl on Caps Lock and you're done.
Offline axtran
« Reply #161 on: Wed, 01 February 2017, 07:32:33 »
I've swapped a GON TKL pcb with a tx87 pcb in my tx87 board so i would assume it would be the same for this LZ board
The TX87 PCB is A87 sized, so any other A87 sized will work too.  Meaning you could find the appropriate TKL A87 sized pcb's any of these will work
TX
Gon
PS2AVR
Alphas - alps with new plate
Just wanted to let you know that the GON PCB isn't a direct fit with the last run of these LZ boards. Spacebar is flipped, wires will hit the plate, and there's some clearance issues at the USB port as well.
When comparing a "stricter" A87 PCB like the Leeku TX87:
Spacebar Stabilizer mounts are 180 degree rotated (the TX87 also sticks down a bit, and in reverse, doesn't fit a GON NerD case even if you factor in the USB orientation)
Right Shift stabilizer is also 180 degree rotated
USB port (default) on GON NerD TKL is on the bottom of the PCB (you will have to request one to be produced with it flipped upside down)
I don't know why people keep blindly saying it'll fit into everything out there :D I think I've only seen yuktsi and kin25 make the changes to their plates to accomodate both types of PCBs. The TX87 has HUGE stabilizer holes to accomodate both types of PCBs, and the TGR Jane has more subtle changes to its plate.
MX Silent > MX Vintage Black > Everything Else
Offline poolside
« Reply #162 on: Wed, 01 February 2017, 18:05:41 »
Hi LZ,
Will the surface of the Aluminum treated? I prefer smooth Surface like TX series. Or will it have similar surface texture like the Ergo? Thanks!
I will release the samples soon.
We could use some samples. I am torn between gray winkey with 7u spacebar and wkl silver.  :-\
WKL Silver my dude, it's a classic
I would get dark grey if you're not sure.  silver is kinda plain.
Thanks for your suggestions. Thinking hard about them. Basically, this (from hwood34):
VS this (from Bevo):
Offline loud_asian
« Reply #163 on: Wed, 01 February 2017, 18:12:55 »
Hi LZ,
this is the photo that motivated me to get silver
untitled-39 by photekq-gh, on Flickr
Offline alienman82
« Reply #164 on: Wed, 01 February 2017, 19:36:58 »
removed.
« Last Edit: Thu, 01 March 2018, 13:11:55 by alienman82 »
Offline DanB
« Reply #165 on: Wed, 01 February 2017, 22:35:06 »
Me and ayylmaoman have had some disagreements in the past, but he is 100% right on this one. Grey goes with everything.
Kingsaver, Koala
Offline kconfire
« Reply #166 on: Wed, 01 February 2017, 22:36:27 »
I've owned the 360C, 356CL DGE, and several black boards.
Get dark grey...
Is Dark Gray much better than the black?
I originally put down for Black.. but at the same time I'm getting a Blackbird for myself in black so I'm now torn between Dark Gray and Black lol
First world problem here..
Offline loud_asian
« Reply #167 on: Wed, 01 February 2017, 22:37:15 »
cmon guys don't make me reconsider my color choice
Offline kconfire
« Reply #168 on: Wed, 01 February 2017, 22:38:27 »
I wonder how the Black on this LZ CLS will look compared to Duck Blackbird.
Are they 2 different kind of Blacks?
I just wish I could see the color sample after anodizing to decide for 100%
Offline Mr_BeastQuake
    • Reddit
« Reply #169 on: Wed, 01 February 2017, 22:45:29 »
Get dark grey...
Meh, I've gotten other color boards and black just fits in too well with my speakers, monitor, monitor mount, and mouse. It also is just as neutral as grey and silver (thus these are the 3 colors offered). Silver looks good with contrasting dark colored sets and beige (imo). Grey and black also look good with many sets, just a preference I feel.
Offline kconfire
« Reply #170 on: Wed, 01 February 2017, 22:54:08 »
Get dark grey...
Right.  I initially thought about silver but I felt that it would stand out too much on my desk so that was a turn off.
If I had a money tree I would also have gone for the silver WKL.
For now.. I'm gonna stick with the black LZ-CLS :D
Offline DanB
« Reply #171 on: Wed, 01 February 2017, 22:54:56 »
Buy both and resell the one you like less for the cost of the GB if not more.
Kingsaver, Koala
Offline Cocopah
« Reply #172 on: Wed, 01 February 2017, 22:55:24 »
Man, you guys are making me reconsider my choice of silver.  :-\
Offline alienman82
« Reply #173 on: Wed, 01 February 2017, 22:57:38 »
removed.
« Last Edit: Thu, 01 March 2018, 13:11:48 by alienman82 »
Offline DanB
« Reply #174 on: Wed, 01 February 2017, 22:58:32 »
Now you are stuck with me doing that unless you give me your otd
Kingsaver, Koala
Offline alienman82
« Reply #175 on: Wed, 01 February 2017, 22:59:42 »
removed.
« Last Edit: Thu, 01 March 2018, 13:11:40 by alienman82 »
Offline DanB
« Reply #176 on: Wed, 01 February 2017, 23:08:47 »
I'm not in the 456GT GB
Did you sell the pink one?
Kingsaver, Koala
Offline Kev
« Reply #177 on: Wed, 01 February 2017, 23:10:18 »
Wonder how much a Vantablack case would be...
Offline kconfire
« Reply #178 on: Wed, 01 February 2017, 23:41:46 »
By the way what's up with that 안젤로 루체티 lol
Offline alienman82
« Reply #179 on: Thu, 02 February 2017, 00:46:20 »
removed.
« Last Edit: Thu, 01 March 2018, 13:11:37 by alienman82 »
Offline DanB
« Reply #180 on: Thu, 02 February 2017, 00:47:14 »
it's my name in Hangul.
Koreaboo ;)
Sent from my iPod touch using Tapatalk
Kingsaver, Koala
Offline alienman82
« Reply #181 on: Thu, 02 February 2017, 01:04:59 »
removed.
« Last Edit: Thu, 01 March 2018, 13:11:32 by alienman82 »
Offline DanB
« Reply #182 on: Thu, 02 February 2017, 01:06:56 »
Koreaboo ;)
just have a few good korean friends, I don't obsess over hentai or whatever
It is really funny but two of my Korean friends are basically weebs about Britain. I call them teaboos <3
Kingsaver, Koala
Offline LifeZ
  • LifeZone
« Reply #183 on: Thu, 02 February 2017, 03:47:00 »
TX
Gon
PS2AVR
Compatible PCB TEST
A87 = NO
A87 PS2AVR = NO
NERD = OK (Space bar stabilizer is no problem) bluetooth version is Incompatibility!!
Alphs = OK (alps with new plate)
« Last Edit: Thu, 02 February 2017, 03:49:13 by LifeZ »
LZ Limited
Offline ramnes
  • T fou, mec?
« Reply #184 on: Thu, 02 February 2017, 04:57:10 »
Hey LZ,
Will you declare a low value on the package customs declaration, so that we don't get taxed as hell?
Offline rabbitfire
« Reply #185 on: Thu, 02 February 2017, 08:08:35 »
Hey LZ,
Yes please! 35% import tax for anything over $45 in my place  :rolleyes:
« Last Edit: Thu, 02 February 2017, 08:10:07 by rabbitfire »
Offline Fnzzy
« Reply #186 on: Thu, 02 February 2017, 09:21:13 »
*opens up the parcel and unpacks huge aluminum block with brass weight and PCB*
"why, of course this is only $30!"
Offline DanB
Re: [GB] LZ CLS (Classic TKL) : Order -&gt; Change order deadline
« Reply #187 on: Thu, 02 February 2017, 09:26:16 »
Such a sh!tty old vintage keyboard.
Kingsaver, Koala
Offline rabbitfire
« Reply #188 on: Thu, 02 February 2017, 09:35:28 »
of course I won't put something under $45 to avoid all the payment for tax  ;D ;D ;D
Offline arid_tare
« Reply #189 on: Thu, 02 February 2017, 12:36:07 »
I didn't see it mentioned in the OP, but do LZ's plates usually allow for switch top removal?
Offline wodan
« Reply #190 on: Thu, 02 February 2017, 12:44:02 »
I don't think so.
Offline DanB
« Reply #191 on: Thu, 02 February 2017, 12:47:13 »
Most Kustoms don't.
Kingsaver, Koala
Offline airs
« Reply #192 on: Thu, 02 February 2017, 12:53:27 »
No, and I think its a good thing - switches feel more stable.
Octagon v2, LZ CLS
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #193 on: Thu, 02 February 2017, 16:32:48 »
Wait, I'll have to double check my kit, but I thought the LZ-FE plate allows switch top removal.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #194 on: Thu, 02 February 2017, 16:39:38 »
Yeah, not sure about the plates in this GB, but the plate for my LZ-FE kit does have the switch top removal cutouts.
WTB/WTS/WTT ---->
Offline arid_tare
« Reply #195 on: Thu, 02 February 2017, 16:45:51 »
Yeah, I did some more looking around after I commented; looks like the SE also had the cutouts. It is not a deal breaker in the slightest for me if it doesn't have it. I was mainly just curious.
Offline poolside
« Reply #196 on: Thu, 02 February 2017, 16:50:22 »
The plate picture in the OP has no cutouts.
Offline LifeZ
  • LifeZone
« Reply #197 on: Thu, 02 February 2017, 19:21:18 »
Hey LZ,
of course :D
LZ Limited
Offline iArson
« Reply #198 on: Thu, 02 February 2017, 19:28:16 »
Hey LZ,
of course :D
:thumb:
Any time estimate on samples?
    • Reddit
« Reply #199 on: Thu, 02 February 2017, 19:36:19 »
Any update on if an acrylic insert will work?
