Author Topic: Seeking Advice - Deck 82 Switch Replacement  (Read 75798 times)
Offline pfink
« on: Mon, 01 February 2010, 17:24:18 »
OK, so I've come into possession of a Deck 82 keyboard and I'm contemplating some future mods for it and have a couple questions regarding Cherry switches.
I'm thinking that at some point I might attempt to desolder and remove all or most of the Cherry black switches and replace them with either Cherry blues or Cherry browns. Based on the wiki article here:
http://geekhack.org/showwiki.php?title=Cherry+switches+and+boards
it appears that there are different types of Cherry switches depending on whether they're mounted on a PCB or plate. The Deck 82 switches are PCB mounted so I guess I'll need to replace them with other PCB mounted switches unless the plate mounted switches can be modified and mounted on a PCB.
So, my questions are:
1) Is a PCB mounted version of the Cherry brown switch available? The wiki article only lists digikey numbers for black, blue and white.
2) Can plate mounted Cherry switches be modified to mount on a PCB?
3) Buying 80+ switches from digikey will cost me more than I paid for the keyboard. What's the least expensive common keyboard I can get to harvest either PCB mounted browns (if available) or blues from in order to get started on this?
Thanks.
Offline ricercar
  • mostly abides
« Reply #1 on: Mon, 01 February 2010, 18:15:59 »
They can be mounted without modification
Yes, all plate mounted browns are PCB mountable. Evidence suggests they are the same.
Yes. See immediately previous answer, and invert.
Compaq 11800 = browns
Scorpius M10 = blues
For the next n posts, expect (n + 1) different and conflicting answers.
« Last Edit: Mon, 01 February 2010, 18:20:42 by ricercar »
Offline Chao
« Reply #2 on: Tue, 02 February 2010, 00:36:44 »
The Cherry website, although nigh-incomprehensible at times, does make a big deal about the different mounting options. Pretty much every type of diagram has two forms, one for with guiding pins, and one for without:
http://www.cherrycorp.com/english/switches/key/mx.htm
» Filco Majestouch FKBN87M/EB
» Cherry G80-3600LYCEU
Offline ricercar
  • mostly abides
« Reply #3 on: Tue, 02 February 2010, 01:18:28 »
That Ricercar is full of ****; don't listen to him. I just tried to replace a switch in a LED keyboard, but the mx LED and mx regular diode switches have different lead spacing.
Offline pfink
« Reply #4 on: Tue, 02 February 2010, 03:30:44 »
Quote from: ripster;155494
Let me be the first to contradict Ricercar.  There are two different versions of the Cherry lower housing, one with guiding pins and one without.
OK, so I guess the Scorpius M10 is the least expensive source of PCB mounted Cherry blues. What about browns? Are the switches in the Compaq 11800 PCB or plate mounted?
Offline itlnstln
« Reply #5 on: Tue, 02 February 2010, 07:26:22 »
The MX11800 is Cherry-made, and thus, PCB-mounted.  Used, the MX11800 will probably be the cheapest brown 'board available.  Otherwise, you will have to step up to the i-Rocks 6230 or the Cherry G80-3000 from Datacal.
Offline itlnstln
« Reply #6 on: Tue, 02 February 2010, 09:56:52 »
That... actually... sounds pretty horrible.  I think I would just buy a new keyboard.  I almost don't like spending the time to swap keycaps.  I'm pretty lazy, though.
Offline Mental Hobbit
« Reply #7 on: Tue, 02 February 2010, 10:29:38 »
Quote from: ripster;155610
Worst that could happen is you have to desolder, take apart the switch, swap parts, reassemble, solder.
That's what I'm planning to do with a Steelseries 7G. When I have a lot of time. And new glasses. Next winter. Probably. Or so.
Typing on blues.
Offline billm
« Reply #8 on: Wed, 03 February 2010, 14:55:13 »
I swapped my deck 82 with cherry browns. Using a decent solder puller, and once you get into a rhythm, it doesn't take that long. Maybe 2 hrs.
If it's not ALPS it's crap!
Offline zwmalone
« Reply #9 on: Wed, 03 February 2010, 15:06:55 »
Quote from: pfink;155565
The M10 is plated mounted IIRC.
Can't get enough of them ALPS
Offline itlnstln
« Reply #10 on: Wed, 03 February 2010, 16:36:18 »
Quote from: zwmalone;156003
Correct.  You would probably have to go with the G80-3000 from Gemini to get PCB-mounted blues; which would suit your purpose, because they don't cost much more than the Scorpius M10.  The only problem is, they seem to be out of stock without a solid ETA.
Offline elbowglue
« Reply #11 on: Sat, 27 February 2010, 00:16:32 »
Ok.  Dumb question.  Does the deck 82 have PCB mounted switches or plate mounted switches?  Thanks everyone.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline elbowglue
« Reply #12 on: Sat, 27 February 2010, 00:17:04 »
Oh wait.  I read the OP.  It's PCB mounted.  Smart am I.
Well, another question.  Would it be as simple as popping the top of the housing off and removing the spring, then replacing with your new spring and new stem and new top?  Or is there something funny with the LED you need to worry about?
Thanks again :P
« Last Edit: Sat, 27 February 2010, 00:19:54 by elbowglue »
Offline elbowglue
« Reply #13 on: Sat, 27 February 2010, 01:58:47 »
Ohh..  that is not easy.  Wait, so you can't even pop the top of the cherry switch on a deck Keyboard without unsoldering the LED first?
« Last Edit: Sat, 27 February 2010, 02:01:38 by elbowglue »
Offline pfink
« Reply #14 on: Sat, 27 February 2010, 14:06:16 »
Quote from: elbowglue;161094
Correct. The top of the switch can't be popped off because the LED is in the way.
Offline ricercar
  • mostly abides
« Reply #15 on: Sun, 28 February 2010, 16:31:22 »
So my bad switch on a BLT-82 requires ...? Anyone have a convenient link to a plate + PCB switch replacement guide?
Crap crap crap.
Offline ricercar
  • mostly abides
« Reply #16 on: Sun, 28 February 2010, 18:48:32 »
> Unsoldering the switch AND the LEDs can be a PITA.
Yah, I've opened it up and lost all ambition maybe four times so far.
Thx for the link. I hadn't realized your Kinesis pad had a plate too.
