Author Topic: Is this the silenced version of the 87u?  (Read 3333 times)
Offline Crix79
Offline Hammithimmis
Re: Is this the silenced version of the 87u?
« Reply #1 on: Fri, 27 January 2017, 13:42:04 »
Yes it is.  For Realforce silent boards, the model name always ends in S (SE170S)
Offline Crix79
« Reply #2 on: Fri, 27 January 2017, 14:48:36 »
Are you sure? On Amazon the realforce is 87UB but the silenced version should be 87USB as shown here:
https://i.imgur.com/mrLYKB9.jpg
They writed the wrong model number or they forgot to mention that the keyboard is silent and that is 87USB and not 87UB?
« Last Edit: Fri, 27 January 2017, 14:50:29 by Crix79 »
« Reply #3 on: Fri, 27 January 2017, 19:43:07 »
On Amazon it goes by the model number SE170S, so it is the silent version.  That keyboard also goes by the model name "87UB low noise", so that is probably why the title shows 87UB instead of 87USB. Always check the model number over the model name, since model numbers are always unique.
https://deskthority.net/wiki/Topre_Realforce#Tenkeyless
Offline Crix79
« Reply #4 on: Sat, 28 January 2017, 10:36:44 »
Ok, thanks
