Author Topic: DYI usb cable does not recognize device  (Read 1905 times)
Offline mniels
« on: Sat, 28 January 2017, 22:24:21 »
OK, tried this cable out before finalizing the housing, etc.  Worked, but after I sleeved it and tried it again Windows give a message that the device is not recognized.  Loose cable, possibly?
Offline pixelpusher
Re: DYI usb cable does not recognize device
« Reply #1 on: Mon, 30 January 2017, 00:49:17 »
My guess is touching wires inside the connection.  Just remove the shrink wrap and make sure you didn't leave any unstripped sections too long.  I find the top pins like to bend down, which will usually end up in the wires touching.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #2 on: Mon, 30 January 2017, 00:55:51 »
Sounds like an issue with the data - (pin 2/top pin near +5VDC).  It might be your data +, but more than likely as the previous post said, that top pin shifted or broke its weld.
