Author Topic: Harvesting Matias Switches  (Read 1683 times)
Offline s0nia
« on: Sun, 29 January 2017, 14:56:45 »
Has anybody experience with harvesting the switches from a Matias keyboard? I've got a Matias hardwired Dvorak keyboard, and I either want to mod it into qwerty or harvest its switches to use elsewhere.
Re: Harvesting Matias Switches
« Reply #1 on: Sun, 29 January 2017, 14:58:51 »
   You just desolder and remove them not sure what else your wanting to know.
Offline s0nia
« Reply #2 on: Sun, 29 January 2017, 15:21:10 »
Right, I was just wondering if those who've done it already encountered anything particular to the Matias boards :)
Offline AfterDark3
« Reply #3 on: Sun, 29 January 2017, 15:36:52 »
Don't forget, you can simply buy Matias bulk switches from them. They aren't particularly expensive.
Offline s0nia
« Reply #4 on: Sun, 29 January 2017, 15:51:10 »
Thanks, but they're out of stock :/
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #5 on: Mon, 30 January 2017, 02:25:00 »
I'm about to desolder a V80 with matias quiet clicks.. i'll let you know if there are any differences but I dont expect there to be. At least not with the switches.
-Dana
Offline s0nia
« Reply #6 on: Tue, 31 January 2017, 11:12:44 »
Thanks, pal! How did it go?
Offline OfTheWild
« Reply #7 on: Tue, 31 January 2017, 11:18:13 »
Haven't done it yet... I should be getting my new solder sucker tomorrow and will give it a go.
-Dana
