Author Topic: Ergodox Infinity Keys Repeating  (Read 2854 times)
Offline sayitaintjonas
« on: Mon, 30 January 2017, 10:40:48 »
Hello folks. I just purchased a used Ergodox Infinity and I'm experiencing some issues with it. Every few minutes, one random key I press will repeat indefinitely until I unplug the USB cable.
I've flashed both halves using the Input Club configurator, but nothing seems to help.
Does anyone have knowledge of this issue or have an idea where I can start troubleshooting?
Offline 3K
Re: Ergodox Infinity Keys Repeating
« Reply #1 on: Mon, 30 January 2017, 11:39:17 »
I guess the repeating key is not physically stuck when repeating, is it?
Is the location of the repeating key really random, or is it possible to limit the position to an area of the keyboard, like a specific row or something? The issue then might be PCB related.
Does any of the keys feel different or weird when pushed? The issue then might be switch related.
« Reply #2 on: Mon, 30 January 2017, 11:43:45 »
I don't think it is the actual switches. The board has MX Browns and I can feel them disengage. I've also made sure to pull the key up when the letters start repeating.
I've made a note of which keys I've had issues with and they are on different rows and columns :(
« Reply #3 on: Tue, 31 January 2017, 11:22:52 »
Looks like the problem has something to do with existing software or drivers on my main PC. I've tried the keyboard on my laptop, HTPC, and my wife's computer without any issues.
Offline flashjac
« Reply #4 on: Wed, 01 February 2017, 04:09:44 »
This often happens when there is not enough power supplied by the computer to the USB port, although I'm not sure if that is the issue you have. If it is a desktop, is there any difference if you use the back USB ports instead of the front, or vice versa?
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #5 on: Fri, 03 February 2017, 18:53:03 »
What OS are you running?
If it's macOS there are issues with karabiner not working correctly (they implement something in the USB HID stack incorrectly, so you'd need to uninstall it).
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
