Author Topic: Electrical question?  (Read 2205 times)
Offline pixelpusher
« on: Tue, 31 January 2017, 08:25:10 »
Okay, so I test a PCB by touching a paper clip to the holes for each switch with Switchhitter open to show me registered key presses, right?
I've done this for 3 boards now and it's a great tool... however, I just started to wonder why am I not getting electrocuted?  Can anyone explain.  I'm obviously touching the circuit.  I'm thinking the USB connection delivers 5V max to the board, right?  Maybe that's not enough to cause a shock?
Sure wish I would have taken some sort of electrical fundamentals courses in college now :(
Offline need
Re: Electrical question?
« Reply #1 on: Tue, 31 January 2017, 08:38:50 »
I'm not sure man.
« Reply #2 on: Tue, 31 January 2017, 08:51:48 »
5 volts DC @ 1/2 amp max is not really a lot of current. And you are probably clothed and sitting or standing on a non-conductive floor.
Electricity needs a completed circuit to flow through.
- D Trump 2026-10-24
Offline pixelpusher
« Reply #3 on: Tue, 31 January 2017, 08:56:07 »
So it's easier for the electricity to just keep flowing through the paper clip than it is for it to flow through me, maybe?
« Reply #4 on: Tue, 31 January 2017, 09:17:58 »
Yes, and: where would it get off after "flowing through" you?
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #5 on: Tue, 31 January 2017, 09:57:06 »
The simple answer is electricity takes the path of least resistance. And you're a poor conductor.
-Dana
Offline pixelpusher
« Reply #6 on: Tue, 31 January 2017, 10:01:19 »
But let's say (hypothetically) the USB connection was supplying something like 120Volts of power.  Would I still be perfectly safe touching the paper clip?  I've touched enough hot wires in outlets to know that my feet on the floor (with shoes on) is still a perfectly fit path for electricity.  Translation: I've electrocuted myself several times on AC outlets.
« Reply #7 on: Tue, 31 January 2017, 10:36:21 »
Think of all the birds that you have seen clutching 500KV overhead lines carrying thousands of amps.
Offline OfTheWild
« Reply #8 on: Tue, 31 January 2017, 10:44:41 »
if you had a paperclip relative to the amount of imagine it like water through a pipe. There are lots of water analogies that people use to explain watts and volts vs. amps and unfortunately electrical engineers are always the ones trying to explain it.  :)) There are a few "ELI5" (explain like i'm 5) posts on reddit about this very subject i'm sure.
-Dana
