Author Topic: Looking for Aqua/Teal 1.8mm LED  (Read 3189 times)
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« on: Tue, 31 January 2017, 13:12:31 »
I am not having any luck online finding an aqua or teal colored LED at a 1.8mm profile and am hoping someone here might know where I could find some???
Offline Jeu
Re: Looking for Aqua/Teal 1.8mm LED
« Reply #2 on: Tue, 31 January 2017, 19:21:00 »
I bought these and the ice blue or sky blue can't remember. One was very green and the other was light blue. Will have to double check. I think these cyan ones were in fact very green.
Offline Jeu
« Reply #3 on: Tue, 31 January 2017, 21:09:03 »
Yeah the cyan ones are very green.  Less yellow than a normal green LED and more blue but it still looks green until you compare directly to a green LED.  You can see here pictures of them.  Hard to capture them for myself.
https://geekhack.org/index.php?topic=64915.msg2004522#msg2004522
« Reply #4 on: Wed, 01 February 2017, 11:19:10 »
Thanks, that is super helpful!! The Cyan definitely is on the green side, I think that will work for my build though! *fingers crossed*
Offline Jeu
« Reply #5 on: Wed, 01 February 2017, 12:15:59 »
Looking forward to it :D I was in the same boat looking for lighter blue LEDs for Hydro.  Was quite the search.
