Author Topic: Universal TKL plate CAD files for Filco/phantom/CM quickfire compatible?  (Read 3130 times)
Offline Panzerhawx
  • Endgame is a lie. You just end up buying more.
    • cartel
Bumping an old thread,
...but by any chance does anyone still have the CAD files for the finalized design? I'd like to print my own.
« Last Edit: Fri, 03 February 2017, 07:57:35 by Photoelectric »
Offline xondat
  • i'm not a star
Re: Re: [GB] Universal TKL plate (Filco/phantom/CM quickfire compatible)
« Reply #1 on: Fri, 03 February 2017, 07:50:02 »
If you have no luck, it shouldn't be too hard to recreate. If you have no luck, hmu.
Offline Photoelectric
« Reply #2 on: Fri, 03 February 2017, 07:57:04 »
You bumped a 3-5-year old GB thread :)  Moved your question to the DIY section, where you'll probably get a better answer.
« Last Edit: Fri, 03 February 2017, 07:59:39 by Photoelectric »
Offline sony
  • Formerly ultraidiot
Bump. I am also looking for this file.
Sent from my ONEPLUS A3000 using Tapatalk
Offline nickheller
  • Cherry ML life
    • hickneller.com
I am almost positive there are files for the phantom plates in the gh cad resources thread
