Author Topic: Shaving keycap stems  (Read 4368 times)
Offline smithyithy
  • a l p s
« on: Fri, 03 February 2017, 08:43:13 »
Just curious really, I suppose it depends on a few factors but how difficult would it be to shave down a cap stem?
For some context, I'm wondering if a Topre-stem could be shaved down to fit into an Alps/style switch. It wouldn't need to be 100% perfect as it would be like an artisan and sit in the ESC space, but I wonder if the male stem of a Topre cut be modified with a decent craft knife to fit snug/straight enough..
Am I crazy? I'm apprehensive about taking a knife to a £40 keycap but at the same time it could result in the perfect finishing touch for my board..
KBD75; Alps64 trio; some other stuff
Offline keytohopiness
Re: Shaving keycap stems
« Reply #1 on: Fri, 03 February 2017, 09:41:57 »
No, sorry.
« Reply #2 on: Sat, 04 February 2017, 22:50:35 »
I tried carving an MX keycap stem to fit Topre, long before MX-compatible Topre sliders were available.
Although I ended up with a keycap that would fit on, it wouldn't stay on.
Some talented artisans have since created a TMX stem which fits on Topre and MX without modification.
A better bet would be to remove the old stem and superglue a new stem in.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #3 on: Sat, 04 February 2017, 22:54:47 »
You probably could do it. It would just require careful work and patience.
What does the stem look like by the way?
Offline smithyithy
  • a l p s
« Reply #4 on: Mon, 06 February 2017, 02:48:25 »
Well I was thinking it would be easier to cut down an MX stem as there's less material to remove. I think if you cut the vertical 'slots' off, with a bit of filing it would probably fit in an Alps switch.
Don't know if I'm willing to butcher a cap to make it fit though :/
I'm looking at casting some caps myself anyway, and Alps fitment will definitely be an aim.
