Author Topic: Sandblasting aluminum for a semi-gloss finish?  (Read 4561 times)
Offline Photoelectric
« on: Fri, 03 February 2017, 09:02:59 »
I'm a little confused what the preparation process is for a semi-gloss finish of anodized aluminum.  For example, GON used to offer his keyboards in "no glare", "semi-glare", and "glare" options--all were textured, sand-blasted type, but I think the size of grain different, from fine grain being matte to large grain being shiny.  I know a number of custom keyboard makers routinely offer this finish, such as LifeZ, Duck (especially), FMJ, some others.  I've asked one of them about the process and was told "sandblasting" + "bright anodizing".  So bright anodizing, as done in the U.S. shops I've called, basically is done on more satin type finishes, smoother ones, and I thought that doesn't really add gloss on its own.  Just makes a part lighter prior to anodizing, unless I misunderstood.  It's the underlying texture that can be glossy or matte, and anodizing itself (that is converting top layer to an oxide) actually slightly dulls a surface anyway.
So I called a local shop that does metal finishing, including sand- and bead-blasting, and the guy told me he'd never heard of a glossy finish after sand or bead blasting--that it's usually more on the matte side.  That it does have some sheen on it, but not much.  I don't know if he means that it's simply not as glossy as a high polish aluminum surface, but what I'm looking for is Duck keyboard-level of gloss, like this:
Not matte like this (outer case):
If anyone could give me some tips on what to request when speaking with a finishing shop, that'd be great.
« Last Edit: Fri, 03 February 2017, 09:10:04 by Photoelectric »
Offline OverKill
Re: Sandblasting aluminum for a semi-gloss finish?
« Reply #1 on: Fri, 03 February 2017, 17:52:43 »
The top picture is zinc plated and the bottom picture looks like it was anodized.
« Reply #2 on: Fri, 03 February 2017, 19:49:14 »
They are both anodized, not plated with anything.
I've figured it out.  Bright dip anodizing is the key, it adds the extra gloss by smoothing out the finish in a certain way.
