Author Topic: ALPS BLUES/HEAVY BLUE/LOCK CREAM NEC PC-8801 Unknown switch?  (Read 17871 times)
Offline Wingklip
  • I am the one the one the one the one the one
« on: Fri, 03 February 2017, 09:11:36 »
Is it rare?
Took me a while to find one in one of the million hard offs in japons159512-0
Edit: I have managed to get out the stem from the back of the switch slider lmao. Just a needle or a screwdriver with a fine enough tip was able to do it xd
« Last Edit: Sun, 12 March 2017, 01:57:15 by Wingklip »
If you 1v1 me in a cage fight I will use an AK-74 for ranged and an IBM model F 122 for melee
Offline y11971alex
  • Looking for Toronto meetup
Re: ALPS BLUES PC 8801
« Reply #1 on: Fri, 03 February 2017, 17:21:18 »
Is that a stem inside the slider?
Offline need
« Reply #2 on: Fri, 03 February 2017, 17:33:12 »
That's a stem I'm pretty sure.
I haven't seen this in my whole life before, so I'm guessing it is rare.
Offline happylacquer
  • BS Apologist
    • BHOBuds
« Reply #3 on: Fri, 03 February 2017, 18:19:16 »
Considering ALPS is a japanese company lots of boards of that era probably use them.
How many PC88 keyboards have blues, i couldn't tell you.
It's a cool board nonetheless and would probably be fun to use.
Offline Mattr567
« Reply #4 on: Fri, 03 February 2017, 18:51:00 »
Nice find. Some of these boards are known to have Blue's.
What are you going to do with it? If you are going to desolder it for the switches or something I would be interested in the keycaps.
IBM P77, SKCC Green, 1984
Offline E3E
« Reply #5 on: Fri, 03 February 2017, 19:27:30 »
Is it rare?
Took me a while to find one in one of the million hard offs in japons (Attachment Link)
Ahh yeah, you see these in Japan fairly often. Nice dyesub alphas. Are the mods doubleshots? Kind of weird; I've never noticed it before, but it seems like a blend.
Should be worth anywhere between $100-250 (mainly for the sake of the switches alone) or more if you're lucky. Blue Alps fever can get crazy sometimes. It's a shame the key cap broke off, do you still have the broken one?
Offline Wingklip
« Reply #6 on: Fri, 03 February 2017, 19:31:18 »
Strangely there was another also with a slightly different blue shade, but those were tactile? What
I'm planning on restoring it to the best of my ability and somehow soarer converting the protocol through the cable if at all possible.
The only issue is that I don't know where to find the plug for it, as it has 3 rows of 2*4 pin and 2 pin on top
How rare would blue alps market for? Also I need to repair the spacebar a bit as it seems one of the tabs have broken. Any ways to remove that stem as well? I "stole" a 0 off the second keyboard that I didn't buy and plan to put it on this.
They look like dye sub PBT and double shot abs
Offline Mattr567
« Reply #7 on: Fri, 03 February 2017, 19:39:11 »
Sounds like that other one was also SKCM Blue. Alps wasn't super consistent in their color shades.
Yea you can remove the stem. The best way is to push it out from the other side like this http://imgur.com/a/zSPux
« Reply #8 on: Fri, 03 February 2017, 19:45:01 »
Ha Ha Ha
- Franklin Roosevelt 1933
Offline E3E
« Reply #9 on: Fri, 03 February 2017, 19:49:40 »
A wax-carving tool I have had its tip bent from wear and ended up being insanely useful for removing broken stems like that from switches. Since Alps Electric (and many other Alps mount) stems are hollow, it slips in the space and then hooks under the bottom so you can pull the stem out with it.
Any thin tool with a tip bent like that should do the trick. Alternatively, taking the switch apart and using a thin tool to push the stem out from the openings behind the mouth of the slider would work. Using the first method is much more hassle free and I love it.
As far as rarity for this one goes? Not super rare in Japan, but I'd say in western markets it is definitely rare. You'd probably have a better shot at aiming this one at enthusiasts of the Japanese NEC PC 8800 series abroad than you would trying to focus it at mechanical keyboard fans.
You say the other ones were tactile and not clicky and also blue? Can you take a picture of that? It's true that it could be another SKCM Blue, as the colors are often pale and inconsistent. Maybe one with a worn click leaf? Hmm.
« Last Edit: Fri, 03 February 2017, 19:51:47 by E3E »
Offline Mattr567
« Reply #10 on: Fri, 03 February 2017, 19:52:50 »
That what I thought.
Offline Wingklip
« Reply #11 on: Fri, 03 February 2017, 20:26:30 »
Strange because all the keys were all equally tactile and none were clicky... They're all the way back in the south end of Chiba so giving it another run would be another $20 train ticket. They felt more like alps whites tbh
Offline Mattr567
« Reply #12 on: Fri, 03 February 2017, 20:36:48 »
I would say its worth it. The caps are worth the train ticket alone.
I'd be interested in it too.
Offline E3E
« Reply #13 on: Fri, 03 February 2017, 20:42:23 »
Yeah, you never know with Alps; there's always something new hiding just around the corner. SKCL Striped Ambers were the first discovery in a long time. SKCM Greens were first documented over here by nubbinator, but they were already somewhat known in Korea at least because an example of the DKSaver OTD custom had them before that.
It was ohaimark, Mattr567, and myself who discovered SKCL Striped Ambers.
It's not often that you find something completely new, but it's very possible with Alps, from key cap profiles to key switches. They were very creative.
Offline Wingklip
« Reply #14 on: Fri, 03 February 2017, 21:26:33 »
I'm on a very tight budget now though as I am mainly looking for the IBM 5576-001/2
If you guys are interested though I'll give it a shot, though postage from Australia is pretty cancerously expensive
Offline Mattr567
« Reply #15 on: Fri, 03 February 2017, 21:47:06 »
With the SKCM Blue craze, they aren't gonna care, trust me :)) Still interested myself too.
Offline Wingklip
« Reply #16 on: Fri, 03 February 2017, 22:21:32 »
Here are some caps 159620-0159622-1
Offline Mattr567
« Reply #17 on: Fri, 03 February 2017, 23:11:39 »
Dyesub PBT.
Offline subcat
« Reply #18 on: Fri, 03 February 2017, 23:33:04 »
Won one of these on Yahoo! Auctions recently, but beware, not all of them have ALPS...
Offline E3E
« Reply #19 on: Sat, 04 February 2017, 00:00:21 »
Dyesub PBT.
It's interesting because these are dyesubs for the alphas, but there's no way the dark keys are dyesubbed. You don't often see doubleshot/dyesub mixes on the same board. The Xerox 6085/DocuTech is one other one I can think of.
Oh really? I have a few 5576-002s actually. You're curious to try Alps Plate Spring? I'm not sure if I'd trade one for these, but I guess I should mention that I do have some. I'm trying to sell them, but they definitely wouldn't fit into any tight budget.
Offline Mattr567
« Reply #20 on: Sat, 04 February 2017, 00:24:22 »
Just like the Model F, that **** can get really expensive.
IBM P70 is my best chance.
Offline Wingklip
« Reply #21 on: Sat, 04 February 2017, 03:26:46 »
Dyesub PBT.
A tight budget of $250 incl postage?
Offline Wingklip
« Reply #22 on: Sun, 12 March 2017, 01:48:58 »
UPDATE AND MANY PHOTOS!!!!!111!1!1!!1
162741-0
PM me if you have a beam spring board and are willing to trade it with this (negotiable lol)
I think I found a new alps blue switch. Heavy blue clicky alps. Has a marker dash! :0
162733-1
162735-2
Inside:
There is a visibly denser spring for the heavy switch, with what it seems double the coils of the first spring from a normal weight part of the board.
162737-3
Outside:
SKCM CREAM Locking switches :D kind of clicky
162743-4
Switch housing and comparison of the two keycaps:
162739-5
162747-6
Double shot abs/dye subbed pbt:
162745-7
It is cracked on the right side, a small chip of plastic is missing. I managed to repair the spacebar which had a broken clip too with some super glue, just heads up
« Last Edit: Sun, 12 March 2017, 01:59:40 by Wingklip »
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: ALPS BLUES/HEAVY BLUE/LOCK CREAM NEC PC-8801 Unknown switch?
« Reply #23 on: Sun, 12 March 2017, 06:01:49 »
Noice, congratulations on the discovery! :D
How heavy are the blues, roughly? Did you measure them with anything yet? Are they noticeably stiffer, then?
Offline subcat
« Reply #24 on: Sun, 12 March 2017, 06:06:49 »
Wait, this is new? That mousefan article on these boards has existed for ages. I have 2. I believe he said it was 200g. Here is the source; http://mousefan.telcontar.net/image/pc8801.htm
They are gorgeous boards! If Heavy Cream and Heavy Grey are on the wiki, so should be Heavy Blue.
Offline Wingklip
« Reply #25 on: Sun, 12 March 2017, 06:59:07 »
Lol heavy blue isn't on the wiki
XD
Guess I'm a bit late lol. They are very heavy. At least twice the weight, so mousefan should be right
But weight! He mentioned nothing about the marker pen! xdddddd
It's a discretely different switch, so let's compromise and say be both discovered something new xd
Anyways I will slowly post these pictures onto deskthority wiki.
In the meantime please tell me this is maybe worth your Beamspring some (pls)
« Last Edit: Sun, 12 March 2017, 07:03:21 by Wingklip »
Offline subcat
« Reply #26 on: Sun, 12 March 2017, 07:00:02 »
That's what i mean, you should add it.
Offline chyros
  • a.k.a. Thomas
« Reply #27 on: Sun, 12 March 2017, 07:37:02 »
Ah, that must be why I missed it xD .
Offline Wingklip
« Reply #28 on: Sun, 12 March 2017, 07:56:09 »
Please milord, spare a Beamspring for a poor peasant?
Offline subcat
« Reply #29 on: Sun, 12 March 2017, 07:57:11 »
Beamsprings are worth quite a bit more than these, sadly, not to mention the shipping fee to here  :'(
Offline Wingklip
« Reply #30 on: Sun, 12 March 2017, 07:59:23 »
Pretty rare board. I would throw in 2 alps blacks boards too on the side to square up the weight
Offline subcat
« Reply #31 on: Sun, 12 March 2017, 08:01:24 »
They aren't that hard to find in Japan, I saw 4 come up for sale during the month I spent on yahoo auctions. They're cool though, maybe you'll find someone willing to trade.
Offline Wingklip
« Reply #32 on: Sun, 12 March 2017, 08:33:23 »
Naannnnniiiiiiiiiiiiiiiiiiiiiiiiiiiiď
Offline E3E
« Reply #33 on: Sun, 12 March 2017, 11:52:08 »
I've seen these quite a few times, yeah. Seems like another case of a heavy switch on a Japanese PC board. The Sharp X68000 also has a "heavy cream" switch on one position with its own black lipstick. It seems that people just haven't been scrupulous enough to document the one-off switch on these boards.
Offline TomahawkLabs
« Reply #34 on: Wed, 28 August 2024, 21:21:36 »
I just bought two of these myself and was excited to learn about the "heavy blue". The black marking appears to just be a marker as it easily comes off with a little pressure. It is hard to overstate how much heavier these springs are. It makes you wonder what the design choice of having an aggressively heavy spring would be. There is a second lock switch under the bottom left key (not sure what you would call that, what I assume, Japanese character) which is such a unique thing to see on a board. It's a shame MX Locking switches never caught on.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
