Author Topic: [HELP] V80 "Alps" PCB lifted pad fix  (Read 1771 times)
Offline schoolbus
« on: Sat, 04 February 2017, 09:46:04 »
Replaced the switches on my V80 "alps" edition with orange alps and can't seem to get my 7 key to work properly. In the soldering process I lifted the pad (where the jumper is connected to the switch).
I by no means really know what I'm doing here, tried soldering a jumper first from this to the corresponding pin on the 8 switch but then just got 8 output for both 8 & 7.
Now I tried soldering the jumper to the 6 diode and the 7 will work if I hit both 6 & 8 as well.
Any thoughts on where this jumper needs to actually go? There aren't many references from what I can find on ALPS PCB's (understandably so) for this type of stuff, just Cherry but again I'm lost.
Appreciate any help.
overall PCB shot
http://imgur.com/Gt5okkK
problem area
http://imgur.com/OzYo0hx
Hopefully I'm not boned?
update-
fixed it by jumping it to the U switch below
http://imgur.com/6odq7T9
« Last Edit: Sat, 04 February 2017, 13:04:49 by schoolbus »
Offline schoolbus
Re: [HELP] V80 "Alps" PCB lifted pad fix
« Reply #1 on: Sat, 04 February 2017, 11:24:52 »
looks like the trace is obviously on the other side of the PCB which I can't get a good view of for obvious reasons. Should've taken a picture of it lol, guess I'll have to keep playing around with jumpers since I really don't want to desolder everything to see it.
Offline TalkingTree
    • My projects
« Reply #2 on: Sat, 04 February 2017, 12:39:07 »
Try shorting the lifted pad pin to an adiacent switch. Remove the jumper first.
Offline schoolbus
« Reply #3 on: Sat, 04 February 2017, 13:04:16 »
appreciate the tip, I ended up solving it :), updated my OP in case anyone ever stumbles across this again for whatever reason.
