Author Topic: HHKB stock keycaps, visible stem normal?  (Read 5397 times)
Offline kb1200
« on: Sun, 05 February 2017, 18:06:50 »
Is this normal on these keycaps? The top row seems to have visible stems with certain light? I've never noticed this on my cherry boards with double shot PBT caps.
Offline xondat
  • i'm not a star
Re: HHKB stock keycaps, visible stem normal?
« Reply #1 on: Sun, 05 February 2017, 18:29:43 »
Normal. Mine is the same.
Offline Sylvester
« Reply #2 on: Mon, 31 July 2017, 21:41:55 »
normal
Offline kmba
  • Formerly tameone
« Reply #3 on: Tue, 01 August 2017, 08:27:21 »
normal.
keyboards.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #4 on: Tue, 01 August 2017, 08:34:05 »
Yeah — it's common.
Offline hayt
« Reply #5 on: Tue, 01 August 2017, 09:42:14 »
Is this also true for other topre pbt sets?
Offline stevenpa
« Reply #6 on: Wed, 02 August 2017, 01:03:49 »
My grey Leopold FC660C caps have them kinda visible but only at certain angles. I think it shows up more on lighter caps
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #7 on: Wed, 02 August 2017, 02:41:23 »
Conversely, they are not visible on the keycaps on my Leopold Mini C (white).
