Author Topic: Wrist rests  (Read 2710 times)
Offline Tally810
Wrist rests
« on: Sun, 05 February 2017, 23:47:13 »
Just finished up my tx-75 and with the sa caps on it I need a wrist rest. Can anyone recommend a good place to get one?  Not a big fan of wood but if that's all there is that will do.  Thanks! Sorry of this is in the wrong thread.
Offline ArchDill
Re: Wrist rests
« Reply #1 on: Sun, 05 February 2017, 23:53:35 »
I just ordered a custom from /u/Ensulyn on reddit. I have not received it yet but based on his past work I am excited.
He is on here as well with the same name. Ensulyn.
Here is his profile: https://geekhack.org/index.php?action=profile;u=59106
Pm him and he can send you some pics.
Also, he trades work for Fugu Artisans haha
« Last Edit: Sun, 05 February 2017, 23:55:34 by ArchDill »
Offline Tally810
Re: Wrist rests
« Reply #2 on: Mon, 06 February 2017, 00:36:34 »
Nice thanks for the info
Offline zslane
Re: Wrist rests
« Reply #3 on: Mon, 06 February 2017, 12:02:40 »
I use Grifiti Fat neoprene wrist rests. Inexpensive and comfortable.
Offline Tally810
Re: Wrist rests
« Reply #4 on: Mon, 06 February 2017, 13:16:10 »
Will check it out.  Thx
Offline TopreFan333
Re: Wrist rests
« Reply #5 on: Mon, 06 February 2017, 17:16:50 »
Those things are basically disposable. I had mine for maybe 2 months of daily use before it started wearing out.
Offline snarfarlarkus
Re: Wrist rests
« Reply #6 on: Mon, 06 February 2017, 22:34:32 »
Yeah they Grifiti's wristrests don't last long. And in the summer it heats up my wrists...
Offline Erzegovaz
Re: Wrist rests
« Reply #7 on: Tue, 07 February 2017, 03:01:59 »
go for grifiti :D is so confortable and cheap
For the summer u can swap for a wood style
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: Wrist rests
« Reply #8 on: Tue, 07 February 2017, 10:45:53 »
Buy once, buy EK 3-star leather.
Offline phinix
Re: Wrist rests
« Reply #9 on: Tue, 07 February 2017, 15:28:32 »
I never used one.
Are they really make difference?
I was thinking to buy one of those wooden ones, like this one: https://www.massdrop.com/buy/npkc-wooden-wrist-rests
Offline Darkmatter35
Re: Wrist rests
« Reply #10 on: Tue, 07 February 2017, 17:26:06 »
Get a "glorious pc" wristrest from amazon. There are two different types (one is thick and one is thin). I like the thin one more.
Offline TopreFan333
Re: Wrist rests
« Reply #11 on: Wed, 15 February 2017, 21:03:48 »
If you have an old Jenga set, you could just do what I did:
It's about 4 columns across for a 60% board, 5 columns for a TKL, and 6 for a full-sized board. Since I took this picture, I added another row, so it's 4 high and 4 across. Height feels exactly right to me. Run a single strip of duct tape underneath to keep them all together. Folds for travel :) Been using this one for about 2 years now, I think.
« Last Edit: Wed, 15 February 2017, 21:06:54 by dchadwick »
