Author Topic: Heavier springs for alu caps. Any recommendations?  (Read 2056 times)
Offline pon10
  • looking at my keycaps..
« on: Tue, 07 February 2017, 11:31:00 »
Hey good folks
I have some alu caps, an the weight offcourse makes the switch feel lighter.
I am trying to figure out which spring is best to replace with. I have gateron greens & cherry clears. I would like to find a spring more heavier than the one in the gat greens.
Any recommondations? :)
Re: Heavier springs for alu caps. Any recommendations?
« Reply #1 on: Tue, 07 February 2017, 13:26:34 »
72g, if you can find them.
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #2 on: Tue, 07 February 2017, 13:43:09 »
Keep in mind that a standard ABS cap weighs between .75 and 1.5 grams. I don't know how heavy your aluminum caps are but the ones I made were about 3.5g. With that in mind, you probably don't have to increase spring resistance that much.
Offline pon10
« Reply #3 on: Fri, 10 February 2017, 02:21:20 »
Awesome, thanks. I will try hunt some down.
Offline pon10
« Reply #4 on: Fri, 10 February 2017, 02:22:49 »
Ok cool, did you up the spring strength? or what switches are you using them with?
« Reply #5 on: Fri, 10 February 2017, 06:26:24 »
Isn't that lighter than the stock springs?
How would that even help?
Offline pon10
« Reply #6 on: Fri, 10 February 2017, 23:39:35 »
in theory i guess the weight of the cap shouldn't matter for the actuation force, right? I don't know if it just me that thinks the spring feels lighter, hehe
