Author Topic: Hello, new member looking for some help  (Read 1967 times)
Offline lambreaux
« on: Fri, 10 February 2017, 10:02:47 »
Hi, I need a new keyboad and made some web seach and I discoverd a new trend with the mechanical keyboards, then i learned about a lot of people recovering old keyboards to use, and this triggered my interest so i found and old very nice ibm and i hope i can foud some help here to fix it.
Thanks for the space.
Offline jal
  • I can't believe it's not gravy!
Re: Hello, new member looking for some help
« Reply #1 on: Fri, 10 February 2017, 10:45:03 »
I wouldn't call it a *new* trend, but welcome aboard! (So to speak.)
So the first thing you'd need to do is figure out what's wrong with it. Visible damage? Nonfunctional? If nonfunctional, in what way?
If you poke around in the 'Keyboards' forums, you'll likely find folks doing similar things. If your modifications to the board is going to be extensive, poking around in the "Making Stuff Together" section might be good.
Offline lambreaux
« Reply #2 on: Fri, 10 February 2017, 11:05:56 »
If you poke around in the 'Keyboards' forums, you'll likely find folks doing similar things. If your modifications to the board is going to be extensive, poking around might be good.
Hi, I opened a new topic in the "Making Stuff Together" section, I hope i can get any help.
Best regards
