Author Topic: 'cause I was bored.  (Read 4630 times)
Offline alipstadt
    • http://www.lipstadt.com
'cause I was bored.
« on: Wed, 03 February 2010, 18:19:47 »
And I got my first Filco yesterday, and the keys were a bit light, and I was curious, and the other one was in view, and I was bored:
Err yeah.  And I need to clean those keys.  Ok, I'll be quiet now.
Adam
On the go:
HHKB Pro JP Black | TG3 KBA-BL82-5RBUVS | Apple Compact Aluminum (USB and BT) | G84-4100PTMUS | Filco Zero Fukka Tenkeyless (broken, for the moment)
At home:
IBM/Maxiswitch M13 Black + Nostromo n52 + Logitech diNovo Mini | G80-11903LPMUS/03 | Model F (AT) with Keypatch 10 | G80-8113HRBUS-2 | TG3 KBA-BLT-5RBIVS | Deck 82 Toxic | G84-4100PTMUS
Other Pieces:
FrogPad Bluetooth, (right hand) | Datahand DH200 | Chicony KB-5181 | AEKII | Power Computing/Macally MK 105X | Sun Type 6 USB | Sun Type 5c | Airlink/Dolch Luggable K6 with Blue Cherries
Offline alipstadt
'cause I was bored.
« Reply #1 on: Wed, 03 February 2010, 18:41:10 »
Yup, my AEKII is looking a bit naked at the moment. In the meantime, I did the rest of the interior letter sized keys.
Adam
On the go:
At home:
Other Pieces:
Offline alipstadt
'cause I was bored.
« Reply #2 on: Wed, 03 February 2010, 18:48:12 »
Speaking of, is there a cheap source of harvestable double shot Alps?
Adam
On the go:
At home:
Other Pieces:
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
'cause I was bored.
« Reply #3 on: Wed, 03 February 2010, 19:25:29 »
I see your Focus doesn't have a large, red Esc key.
Offline alipstadt
'cause I was bored.
« Reply #4 on: Wed, 03 February 2010, 21:52:26 »
Arg, the U key was intermittent.  I fiddled with it for a bit, and now it functions but the tactile and audible feedback is just slightly different than every other key, but enough that I notice.  I really don't want to send this in.  Can someone tell me how to safely take apart one of these Fukkas?  I'm out at a cafe at the moment, so I won't be doing it right now, but I'd rather not have to send in an otherwise great keyboard.
BTW, I think I like the Apple keys better, giving more of a thunk than the thinner Filcos.
Adam
On the go:
At home:
Other Pieces:
Offline alipstadt
'cause I was bored.
« Reply #5 on: Thu, 04 February 2010, 02:06:44 »
Ugh, the backplate was messed up, which I screwed up further.  I know it wasn't me initially, because I opened another keyswitch to check what the plate should look like, but I made matters worse when trying to put it back (the slight bend became a bigger one).  Now the U requires a ridiculous amount of force to trigger; I need a new plate, or a new switch.
Any idea where I can get one replacement switch?
Adam
On the go:
At home:
Other Pieces:
Offline alipstadt
'cause I was bored.
« Reply #6 on: Thu, 04 February 2010, 09:31:18 »
Ripster, what's the mount compatibility of these this switches?  Could I just pull one from an AEK?  What else might work?
I looked at the pics of a Filco Zero teardown, the Fukka switches look like through hole pcb mounts, is that correct?
I know where to order Cherry switches; is there no component store that stocks these?
Adam
On the go:
At home:
Other Pieces:
Offline itlnstln
'cause I was bored.
« Reply #7 on: Thu, 04 February 2010, 09:33:16 »
ALPS (real and "compatible") can be swapped out with no problem. Bigpook put real ALPS complicated blacks from a Dell into his Filco Zero, so you should have no problems swapping around switches.
I don't know of a component shop that carries ALPS-compatible switches, though.
Offline alipstadt
'cause I was bored.
« Reply #8 on: Thu, 04 February 2010, 09:43:17 »
Ok, well there is one AEKII switch that isn't so dampened any more.  Should make a nice caps lock key. Then again, let's see what donor boards are on the 'bay.
Adam
On the go:
At home:
Other Pieces:
Offline alipstadt
'cause I was bored.
« Reply #9 on: Thu, 04 February 2010, 10:18:23 »
Adam
On the go:
At home:
Other Pieces:
Offline alipstadt
'cause I was bored.
« Reply #10 on: Thu, 04 February 2010, 10:36:22 »
Actually, I like the clicky ALPS more than the dampened ones.  I just decided that the AEKII (really, just decided, had the case open and everything) was in too good of a condition to tear down.  Besides, 6 donor keyboards for $66 shipped is better than one at $60, esp. since I have a SGI fetish and would again finding myself not wanting to kill a keyboard :-)
No such sentimentality over those 6 Dells.
Adam
On the go:
At home:
Other Pieces:
Offline alipstadt
'cause I was bored.
« Reply #11 on: Thu, 04 February 2010, 10:42:45 »
Hmmm.  Can I use the leaf from the Fukka?
Adam
On the go:
At home:
Other Pieces:
Offline alipstadt
'cause I was bored.
« Reply #12 on: Thu, 04 February 2010, 10:52:37 »
Well, I'll have to wait to find one of those. Buying keyboards for my keyboards, ugh.:fear:
Adam
On the go:
At home:
Other Pieces:
