Author Topic: -  (Read 2527 times)
Offline Elikstar
« on: Fri, 10 February 2017, 15:59:16 »
« Last Edit: Tue, 28 February 2017, 12:54:42 by Elikstar »
V7 GK110 | OTM Outemu Blue Switches
TeckNet X886 Gaming Keyboard | Gateron Black Switches
Re: -
« Reply #1 on: Tue, 06 June 2017, 22:23:45 »
Offline TheInverseKey
  • You can run but you cannot hide!
Re: -
« Reply #2 on: Tue, 06 June 2017, 22:26:56 »
Re: -
« Reply #3 on: Tue, 06 June 2017, 22:40:32 »
I tried google translate for '-' but I can't find british to convert it to english. :confused:
Offline DaBubbs
Re: -
« Reply #4 on: Tue, 06 June 2017, 23:03:58 »
:)) I did the same thing.
When you are dead, you don't know that you are dead. It is difficult only for the others.
It is the same when you are stupid.
Offline mrduul
Re: -
« Reply #5 on: Tue, 06 June 2017, 23:17:32 »
 :p
Re: -
« Reply #6 on: Wed, 07 June 2017, 05:33:38 »
Testing punctuation, nothing much to see here.
