Author Topic: elitekeyboards flowchart  (Read 4955 times)
Offline nanu
    • http://T-T.be/portal
« on: Wed, 03 February 2010, 21:19:22 »
I made a purchase consideration flowchart for less-geekhacky internet friends who haven't considered mechanical keyboards at all, in case I find more of them who want to replace their rubberdomes yet may be willing to pay a decent amount.  It's only a matter of time before those domes go bad.
History: ver. 1.0
I (still) only have one mechanical keyboard so its accuracy is based from what I know by having lurked here.
« Last Edit: Fri, 05 February 2010, 09:46:03 by nanu »
Offline bhtooefr
    • bhtooefr.org
« Reply #1 on: Wed, 03 February 2010, 21:41:11 »
You've got noisy pointing to black through one route, and worse, non-noisy pointing to blue.
Offline nanu
« Reply #2 on: Wed, 03 February 2010, 22:30:23 »
Quote from: bhtooefr;156103
Of course it's biased. It's good that you can see it's not entirely logical.
But hear me out: bottoming out will be noisy on any Cherry MX switch, since I consider that on my dampened browns to be loud, so I'm rather picky; I converted from a scissor-switch rubberdome that I consider much quieter, so I guess I was spoiled by that.
Perhaps a flowchart centered upon the notion of not bottoming out, and exchanging "clicky" for "noisy" and its connotations would be more keen and could avoid the pitfalls of the simplification I have chosen.
Offline devilcm3
« Reply #3 on: Wed, 03 February 2010, 22:43:51 »
i loled when i saw the "you want have strong fingers" instead of tired fingers
Black Cherry MX , once you bought it , it is yours , it is permanently yours , it is permanently yours till you meet your maker
1.FILCO Cherry Blue FKBN104MC/EB
2.FILCO Cherry Brown FKBN84M/EB
Offline didjamatic
« Reply #4 on: Wed, 03 February 2010, 22:49:39 »
Awesome and quite informative really.
Elite should give you a freebie for making that.
Offline Viett
« Reply #5 on: Wed, 03 February 2010, 23:18:58 »
I don't see how not wanting a loud keyboard can land you at Blue Cherries.
« Last Edit: Thu, 04 February 2010, 23:26:42 by Viett »
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline Chao
« Reply #6 on: Thu, 04 February 2010, 02:23:19 »
Quote from: ripster;156102
Haha!  I'm still mapping out mine.
I suspect that mapping to "Cars You Drive" or "Did Obama Fake His Birth Certificate" may also work.
File is attached if anyone wants to play with it (rename from .txt to .pptx).
I like the one with the MY switches thrown on the top left better. iirc they were represented by this fellow:
« Last Edit: Fri, 05 February 2010, 17:25:44 by Chao »
» Filco Majestouch FKBN87M/EB
» Cherry G80-3600LYCEU
Offline sethstorm
« Reply #7 on: Thu, 04 February 2010, 20:35:18 »
Then where do Cherry MY keys map out to, near Cherry Blue (but in between them and Alps/Buckling Spring) ?  I've got no problem with them and they feel like they should take a beating.
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
Offline majestouch
  • * Commercial Vendor
    • http:///elitekeyboards.com
« Reply #8 on: Fri, 05 February 2010, 00:47:31 »
Quote from: nanu;156100
Ahh, if only qualifying a customer's requirements were this easy! Not a bad start though;)
Offline hyperlinked
« Reply #9 on: Fri, 05 February 2010, 01:10:59 »
Quote from: majestouch;156368
Good point. In a real world situation, there needs to be a process break at every node of the decision tree that checks "Is this person crazy?"
No allows you to continue on the decision path. Yes, usually means you get referred to the nearest office supply or electronics store to buy the latest permutation of the Microsoft or Logitech Multimedia Keyboard.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #10 on: Fri, 05 February 2010, 07:57:30 »
Quote from: ripster;156125
Flow chart needs diodes?
I lol'd at this one.
(Wrong type of topology though.)
Offline nanu
« Reply #11 on: Fri, 05 February 2010, 09:47:26 »
Updated with more logic (I forgot the crowd we have, here)
Offline itlnstln
« Reply #12 on: Fri, 05 February 2010, 09:54:02 »
Quote from: nanu;156443
No ****.  You can't make a joke around here just for teh lulz.  Everything get dissected and over-analyzed.  FWIW, I appreciated the joke.  Thanks.
Offline lal
« Reply #13 on: Fri, 05 February 2010, 11:17:45 »
Very funny :)
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
