Author Topic: [GB] Let's Split Kits (Closed for Orders)  (Read 29989 times)
Offline deductivemonkee
  • Professional Lurker
« on: Sun, 12 February 2017, 12:54:53 »
ORDER HERE
Prices:
PCBs - $7 USD per set
Case - $24 USD per set
Pro Micros - $10 USD for 2
TRRS Jacks - $2.40 USD for 2
Diodes - $2 USD for 200
WS2812B Led Strips - $8 USD per
Push buttons for easier flashing - $1.50 USD for 2
4.7k Ω Resistors for i2c - 50¢ for 2
Total: $55.40 USD if you got one of everything, plus shipping and PP fees.
This is a group buy for Let's Split Kits! The parts that I am offering are PCBs, Cases, Pro Micros, TRRS Jacks, Resistors for i2c, and WS2812B RGB 1m/60 led strips.
The order form will be open for 2 weeks, until Saturday the 25th. Why not Sunday? I posted this a day later than on Reddit  :-X
This should ship in ~2 months
I will NOT be working on this during spring break, as I have plans
Shipping within Canada should be under $12 USD
Shipping to CONUS should be under $15 USD
INTNL shipping should be under $28
I will be able to calculate shipping better once I know what packaging I can use for your order, and how much it will weigh.
Orders will be shipped in bubble mailers, unless you want to pay more for a box.
Cases are none other than /u/Jolimon cases! They come with top plates, bottom plates, standoffs and screws! Each case comes with enough for one split keyboard.
[Not really FAQ yet but this should make it easier]
How can I contact you?
Here - deductivemonkee
Reddit - /u/deductivemonkee
Discord - deductivemonkee#2100
Email - The email that sent you your invoice  ;)
Do you have pictures?
Not yet. I should have some cases in-hand in the next week. Until then, check out Jolimon's great pictures Here. PCBs are the same as the Black V2s that were available, except these are blue!
What colour will the PCBs be?
The PCBs will be Blue!
Why is shipping so expensive?
Everything is being shipped from me, in Canada. There are cheaper shipping options like lettermail for those who want it, but that will only be available for small orders and will not have tracking afaik. Also keep in mind I would rather over-estimate than under-estimate and have to ask you for more money to ship your order.
Is there a maximum or minimum order for anything?
No, this GB will be like a hamburger. You get what you want
Will you offer switches/keycaps?
No. This is complicated enough as is
Will prices go down with amounts?
Barely.
Can you invoice me in CAD?
All Canadian orders will be invoiced in CAD to avoid PP conversion fees.
Anything else? Ask in the comments!
Current MOQ numbers on cases:
Trans Smoke Gray Case 8+/5
Trans Purple Case 2/5
Trans Neon Orange Case 5/5
Glossy Cyan Case 1/5
Glossy Purple Case 2/5
Trans Neon Pink Case 1/5
« Last Edit: Sun, 28 May 2017, 13:20:52 by Photoelectric »
oh yeah I saw that crazy **** if that doesn't win I'm deleting my account
Re: [GB] Let's Split Kits
« Reply #1 on: Sun, 12 February 2017, 12:56:51 »
Order Form Open
Invoicing
Ordering/Shipping to me
Packaging and sorting
<We are here>
Shipping
« Last Edit: Sat, 08 April 2017, 00:18:18 by deductivemonkee »
« Reply #2 on: Sun, 12 February 2017, 12:57:00 »
Reserved.
« Reply #3 on: Sun, 12 February 2017, 22:54:16 »
Reserved.
Offline fatpolomanjr
« Reply #4 on: Mon, 13 February 2017, 00:48:22 »
I need to add on the $8 LED strip to my google form. What is the best way to do so?
Some guys keep on saying they believe in Jesus, and keep doing a lot of shameful things.
Current GH Classified Post (LF Arcade Floor, Garbield and CYM Otter and Keyng)
« Reply #5 on: Mon, 13 February 2017, 01:04:52 »
I'll add that :thumb:
« Last Edit: Mon, 13 February 2017, 01:08:21 by deductivemonkee »
« Reply #6 on: Mon, 13 February 2017, 01:12:00 »
Great, thanks!
Offline loar
« Reply #7 on: Mon, 13 February 2017, 06:45:08 »
hey, I tried to do some research on this i2c thing and I understood that it has something to do with the 2 pro micro, but don't really understand what it changes on the let's split.
Can someone clear that up for me? ( I ordered the resistors anyway )
« Reply #8 on: Mon, 13 February 2017, 08:14:59 »
I2c reduces latency between the two halves, and theroetically allows you to chain over 100 devices together.
Offline loar
« Reply #9 on: Mon, 13 February 2017, 08:32:03 »
Ok, glad I got the resistors then.
Thank you!
Offline johntron25
« Reply #10 on: Mon, 13 February 2017, 12:54:43 »
Does the bottom plate have a through hole to support the reset button?
« Reply #11 on: Mon, 13 February 2017, 13:04:34 »
No. The reset buttons are something you solder directly onto the GND and RST pins, or with wire. The best way to do this IMO is use bits of wire, and have the button glued next to the pro micro sticking out on the side with the trrs jack.
Offline redbanshee
  • actually Dade Murphy
« Reply #12 on: Mon, 13 February 2017, 13:18:34 »
Looks fun! In for a set!
Offline johntron25
« Reply #13 on: Mon, 13 February 2017, 13:31:12 »
Interesting. On my first let's split, soldered to wires on the RST and GND pins and I would pull them out from the side and connect them together  whenever i need to put the PM on bootloader mode. I guess having a button is more elegant haha.
I was planning on using my own cases which has mid spacers. I don't have room for a reset button on the side. oh well.
« Reply #14 on: Mon, 13 February 2017, 13:33:46 »
If it's your own case design why not add a hole on the bottom for the reset button?  :thumb:
« Reply #15 on: Wed, 15 February 2017, 19:06:45 »
Quick update, sample cases have arrived. Pictured colours are Glossy Blue, Glossy Red, and Matte Clear
« Reply #16 on: Fri, 17 February 2017, 20:03:27 »
Invoices will start going out tonight for all orders except orders with case MOQs not yet met.
« Reply #17 on: Fri, 17 February 2017, 20:53:58 »
Please make sure that everything on your invoice is correct. Once you have paid you cannot change your order or cancel.
« Reply #18 on: Fri, 17 February 2017, 23:34:44 »
All invoices for current orders without case MOQs not met have been sent out!
« Reply #19 on: Sat, 18 February 2017, 23:59:06 »
All invoices are out for current orders. Case MOQs no longer exist!
« Reply #20 on: Mon, 20 February 2017, 19:39:27 »
Paid order's cases have started production. If you have not paid your invoice, the sooner you do, the sooner your case can be made and be ready to ship to me.
« Reply #21 on: Thu, 23 February 2017, 19:18:15 »
All orders placed from now on will be invoiced on Monday. Please pay your invoice ASAP.
« Last Edit: Mon, 27 February 2017, 23:48:59 by deductivemonkee »
Offline KeLorean
« Reply #22 on: Thu, 23 February 2017, 22:28:33 »
I filled out an order form, and I really hope I can figure out how to put this thing together
Click it OR Ticket!
« Reply #23 on: Thu, 23 February 2017, 23:40:15 »
this is a great guide for how to build.
Offline KeLorean
« Reply #24 on: Fri, 24 February 2017, 23:42:48 »
thanks! this looks very educational. do u know of a thread that explains i2c?
Click it OR Ticket!
« Reply #25 on: Sat, 25 February 2017, 00:10:24 »
There is an i2c guide in that page
Edit, wrong git. Lemme grab the right one. this is the correct guide, sorry about that.
« Last Edit: Sat, 25 February 2017, 00:12:03 by deductivemonkee »
Offline KeLorean
« Reply #26 on: Sat, 25 February 2017, 06:45:14 »
ohh! thx. sweet pcb too. is our pcb gonna be pimped out with spike too? if so, how do i change to a clear case?
Click it OR Ticket!
« Reply #27 on: Sat, 25 February 2017, 07:47:23 »
Yes. I changed your order to a clear case.
« Last Edit: Sat, 25 February 2017, 12:17:07 by deductivemonkee »
Offline KeLorean
« Reply #28 on: Sat, 25 February 2017, 12:47:00 »
awesome! i cant wait. thanks for organizing all of this. i think im going to level up my keyboard skillz with this build.
Click it OR Ticket!
« Reply #29 on: Sat, 25 February 2017, 14:48:47 »
I'm pretty sure it's supposed to be lupin III.
Offline mintyfruits
« Reply #30 on: Sat, 25 February 2017, 16:55:12 »
Definitely Lupin. Does his pcb support alps?
« Reply #31 on: Sat, 25 February 2017, 17:56:55 »
Yes
« Reply #32 on: Sun, 26 February 2017, 20:51:17 »
Form is still open tonight, closing at 10:30pm PST. Stragglers, now is the time!
Offline teeseeuu
« Reply #33 on: Sun, 26 February 2017, 22:59:29 »
Thanks for running this. I needed a backup split. First one went together well. Can't wait! really good job on setup.
« Reply #34 on: Sun, 26 February 2017, 23:29:03 »
Order form is now closed. Remaining invoices will be sent tomorrow.
« Reply #35 on: Mon, 27 February 2017, 18:50:47 »
All invoices are sent. Please double check your invoice, and pay ASAP.
« Reply #36 on: Thu, 09 March 2017, 09:17:27 »
PCBs have been ordered, they should be here in 3 weeks. Cases start production this weekend, and everything else will be ordered this weekend.
Offline KeLorean
« Reply #37 on: Fri, 10 March 2017, 21:21:47 »
wow! im so used to doing groupbuys on massdrop and waiting way too long for stuff.  this is sweet! i can be apart of the fast food generation again :D
Click it OR Ticket!
« Reply #38 on: Tue, 14 March 2017, 23:14:38 »
Everything has now been ordered. Now is is just a case of case production (see what I did there?) and everything else shipping to me.
Offline nath5
« Reply #39 on: Tue, 14 March 2017, 23:27:18 »
Sad I missed this GB any idea if there will be another one?
Sent from my Nexus 6P using Tapatalk
« Reply #40 on: Wed, 15 March 2017, 20:56:24 »
PCBs have arrived to me!
163093-0
Offline schoolbus
« Reply #41 on: Wed, 15 March 2017, 21:06:53 »
Well that was a pretty fast 3 weeks :O
« Reply #42 on: Wed, 15 March 2017, 21:07:37 »
Yeah. I think when I asked wootpatoot for a timeline the 3 weeks had already started. Are you in the GB on reddit with another username?
« Last Edit: Wed, 15 March 2017, 21:51:34 by deductivemonkee »
Offline schoolbus
« Reply #43 on: Thu, 16 March 2017, 07:27:42 »
I found it on here but put both my reddit/geekhack name on the order form IIRC- I'm a bit more active on reddit-mattizmyname.
Cheers.
« Reply #44 on: Fri, 17 March 2017, 17:07:08 »
I have sent emails requesting phone numbers, as they are a requirement to ship international.
« Reply #45 on: Wed, 05 April 2017, 21:43:03 »
I have all parts, just waiting on cases. Canada Post says that they will be here for Monday. I plan to start shipping orders without cases this weekend, and orders with cases soon after they arrive.
Offline redbanshee
« Reply #46 on: Wed, 05 April 2017, 22:21:19 »
 :thumb: looking forward to this kit
Offline kmba
  • Formerly tameone
« Reply #47 on: Wed, 05 April 2017, 22:46:14 »
Awesome. My DSA ol set came in the other day.. I'm ready!
keyboards.
« Reply #48 on: Wed, 05 April 2017, 22:57:22 »
I don't have my trrs cables yet
Offline USER9127
« Reply #49 on: Sun, 09 April 2017, 10:21:05 »
So excited for this to arrive. Are cases still on their way? Sadly, I will be working remote, so hopefully usps will hold my order till then. Otherwise *shrug*....
